How do I access the under keyboard memory slot on my e1 system 3001 laptop?
  • 31 Answers
Try this site.
http://www.laptop-computer-comparison.com/installing-laptop-memory.html
Remember to make sure the power is unplugged and you use a wristband to ground you or touch something metal to dissipate static charge before working on any electronics.
Good Luck!
Posted on Oct 02, 2009
Where dom i insert new memmory in a dell latitude d820 computer?
1. Remove the keyboard bezel with a flathead screwdriver.
2. Remove three screws securing the keyboard
3. Unplug the keyboard cable from the motherboard and remove the keyboard. The internal RAM (memory) slot is located under the keyboard, right above the touch pad buttons.
-How to remove keyboard ( with pictures ) -
http://blogs.microsoft.co.il/blogs/tamir/archive/2007/11/16/diy-how-to-replace-your-dell-latitude-d820-keyboard-for-only-13-99.aspx
Aug 21, 2011 | Computers & Internet
How can i get to both memory slots so i can upgrade to 2GB of Ram? Thanks
Your laptop has two memory slots. One of the memory slots (external) can be easily accessed if you remove the cover on the bottom of the laptop.
The second (internal) memory slot is located under the keyboard.
Keyboard removal procedure:
1. Unplug the AC adapter and remove the battery.
2. Remove two screws securing the keyboard on the bottom of the laptop. These screws are marked with a small keyboard symbol.
3. Release 4 keyboard retention tabs located on the left side from f1, f5, f9 and delete keys.
4. Lift up the keyboard and place it upside down on the palm rest.
5. Unlock the keyboard cable connector on the motherboard.
6. Remove and replace the keyboard.
Hope this helps. Thank you for using FixYa.
Sep 30, 2010 | HP Compaq nx8220 Notebook
Satalite m35x-s161 how to replace the keyboard?
Toshiba Satellite How to remove keyboard and upgrade memory modules. This post was written by cj2600 on April 28, 2006
Posted Under: Toshiba Satellite A20/A25 --> toshiba-satellite-a20-a25-memory.jpgRemoving and replacing memory on a Toshiba Satellite A20 or A25 notebook is not as easy ad it should be. Both memory modules are located under the keyboard. A laptop keyboard has to be replaced in order to get access to the memory modules. Before you remove the keyboard do not forget to remove the laptop battery or you can damage the laptop. Be careful when you remove the keyboard securing strip; do not bend it too much. To remove the memory module from the slot on the system board, release the latches on both sides and the memory module will pop up. It will stay at a 30 degree angle to the system board. Firmly grasp the memory module and remove it from the slot.
Oct 31, 2009 | Toshiba Satellite M35X-S161 Notebook
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
Is there another memory slot under the keyboard?
how to check the Ram slot location
1) most laptop have two slots at back, so no other slot under the keyboard
2) some laptop has onboard Ram(on the surface of motherboard) ,if you see one slot at back so no any slot under the keyboard
3) if the laptop no any slot at back it should be one or two slot under the keyboard
your laptop no ram slot under the keyboard
hope it help you to improve your idea
May 09, 2009 | Computers & Internet
Can only find one memory slot/bay for my Inspiron 1720, correct?
The other slot is under the keyboard. You have to remove the top plate then remove the two screws and lift up the keyboard.
Mar 08, 2009 | Dell Inspiron 2200 Notebook
Dell 700m memory upgrade
No, it's not necessary. Verify the memory is compatible with the computer.
Jun 28, 2008 | Dell Inspiron 700M Notebook
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Jan 26, 2008 | Sony VAIO VGN-A690 Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
