I have a hp pavillion a462x with a hp vs19e flat panel monitor. The monitor went black, totally dead. I connected it to another computer and it worked fine. The problem seems to be in the computer. Does the computer need to be replaced?
    Problem Solver:
  • 5 Answers
Many times LCD screens will turn black
but try changing the dispay setting with another monitor such as a crt
Posted on Oct 03, 2009
  • 15 Answers
That could be the video chip if have on board video. I don't know if you have an AGP or PCI slot to add a new video card. The Agp is brown color and always is just one. The PCI are white, and you can have 2, 3 or 4. You can buy some cheap video cards on ebay.
How do get the audio system to work
The speakers have to connect via 3.5mm analog Male to Male cable to an audio source.
Mar 13, 2015 | HP Excellent Vs19e 19" Flat Panel Lcd...
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs19e Flat Panel Monitor. model HSTND-2LO7, product# EN632AA made March 2006. I have no power indication. Checked internal power supply connections and PC mounted fuses. Tested operation with another...
If it's under warranty, then take it back for repair or replacement. If it's not under warranty then plan to buy a new one. Unfortunately, in the modern world, faulty electronics without a warranty on them are becoming increasingly known as "throw away items". This has started to happen with monitors. They call them throw away items because it typically costs just as much or more to have it repaired as it does to replace it with a new one. There are several things that could cause the monitor to go black: Bad inverter, Bad back-lights, Bad throwback (transformer), Bad LCD, & etc. Look for any burned resistors or popped capacitors on the circuit boards also. I've had a few monitors where all I had to do was replace the faulty resistor or capacitor and it worked fine.
Mar 22, 2010 | Computers & Internet
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
My moniter wentr out.
Hmm, haven't had experience with this exact monitor, but several people have had success with my tutorial on fixing the vs19d and vs19e. Check out the link below:
http://boredprojects.blogspot.com/2009/09/hpvs19e-monitor-fix.html
Sep 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My HP vs19e flat panel monitor began taking longer and longer to come on and now it's hours. I'm afraid that one day it's not coming on at all. I have been leaving it on to keep from having to wait but...
Haven't run into this particular problem, but many have been able to fix their monitors that won't come on with my tutorial. See the link below:
Sep 25, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
I want to replace the power switch board on my hp vs19e monitor.
About your only hope for getting a replacement switch is to buy a "Parts Only" monitor off of EBay and carefully remove the switch. This one is tricky it's attached to the front bezel as you've likely found out. When you disassemble the monitor, lay it face down and remove the bac plastic then remove the 4 screws holding the button board on then take the rest apart. That's the safest way.
Mar 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp vs19e
try to see maybe it is mute or inspect the connection of your speaker to your audio jack.i think there is loose contact of your speaker.
Feb 15, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Samsung SyncMaster 191T
You have either a bad inverter board or burned out backlight fluorescent bulb. Very common on this monitor.
Dec 20, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
