Barrel is tilting and off balance with a load of wash
    Genius:
  • Washing Mach... Master
  • 1,460 Answers
Check top srings are intact..
Posted on Oct 02, 2009
If I put more then 2 pair of jeans it won't spin out. Is the censor gone or barrel off
The barrel is out of balance. Remove the jeans and redistribute evenly, or wash fewer pairs of jeans at a time.
Feb 02, 2016 | Maytag Centennial Top Load Washer
Spin cycle does not engage
UPLOADING OR FRONT LOADING WASHER..........CHECK ITS BALANCE LEVELS.
Feb 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Where is the filter at on it
Pull washing machine out from wall about 2 feet. Tilt the washing machine back carefully and let it rest against the wall at about 45 degrees, use a block to prop if wont stay or you are
uncomfortable. Towards the front on the bottom of the barrel at about 5 o'clock, you will see a rubber hose connected to the pump and the barrel, filter is inside. Disconnect from barrel and remove filter.
Dec 06, 2010 | Frigidaire ATF6000ES Front Load Washer
An ue code flashing
Hello
UE is an imbalance error which is displayed when either the load is small or the appliance is tilted. You can also check if the washer is balanced and try unplugging the washer for 15 minutes to check if its balanced. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | LG WM-2277HW Front Load Washer
Very loud shaking during spin cycle
assuming it is a front loader. Check if transport bolts are not still attatched. If not, open back cover and look for shocks for breakage or being siszed. Do you have a noise from the drum while spinning and having no load. If so, the bearings need to be replaced.
Sep 16, 2009 | Maytag MAH8700A Front Load Washer
Basket is off balance. Basket is tilted (not
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 16, 2009 | Washing Machines
We can't seem to balance our washer barrel with or without a load. it spins out of balance. all springs are good.
Is the washer itself balanced? Have you tried adjusting the adjustable "leg" screws on the bottom of the washer?
Washer stops due to being out of balance very easily
Depending on the make and model some washers have a double nut after you level and adjust make sure you tighten the other nut so it doesnt work itself loose under heavy loads..........If it's an older washer look inside the barrel theres springs in there that hold it in place one of these may have come off or may have broken........
May 06, 2009 | Washing Machines
Tub gets off balance and makes noise while washing.
It probably does this because you have overloaded the machine with towels or bedding try putting less in...
Jan 03, 2009 | Washing Machines
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
