Question about NorStar M7208 Corded Phone
Line can be answered, but the phone won't ring
My T7208 does not ring --- the line flashes and can be answered, but you can't hear it ring
Does anyone have any solutions as to why this can be or what to do?
    President:
  • NorStar Master
  • 860 Answers
Sounds like the extension needs to be programed to ring for incomming calls.
ProgrammingLine can be answered, but the phone won't ring - 2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.
When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)continue with the remainder of the incoming lines that you have on your telephone
press the release key when finished
Posted on Oct 02, 2009
  • C_cretguardn Jun 02, 2011
    Thank you SO much for posting a response to this question! You just saved my company $170.00 and me even more headache, after reading the phone manual front to back (221+ pages) and not being able to figure out how to get the phones to ring.
I am using a Nortel T7208/T7316 sets (BCM 450 PBX) system, and I want to program a phone to ring when someone calls the main line. Most of our phones only ring when you type the extension internally. I...
The phone must be programmed with the target line assigned to the number you wish to have ring at that phone. This can be done with the BCM Element Manager interface. If your BCM450 is running version 6, I think this can even be done directly from the phone, but I'm not sure of that process.
Nov 09, 2012 | Nortel Business Series Terminal T7208 -...
I just wanted to ask how to shorten the number of rings before it goes to voicemail on a t7316 and t7208 phone. Thanks
You may need a tech if unsure of programming, passwords and navigation.
In Config or Admin under Sets/Capabilities you will see Forward No Answer, that needs to be pointed to the voice mail ext # (F985 to see what that is), then after that setting is the ring count....4 is recommended for average office staff.
Aug 06, 2012 | Nortel T7316E 2-Line Corded Phone
I cant get my T7208 to ring
Norstar doesn't like phones to be moved around some times on the old norstar systems moving phones caused problems. How old is this system and in programming there is a setting called set relocation this has to be a yes to move sets.To move a set to another local unplug both sets wait 1 min. plug one set in it's new local wait 1 min. plug other set in its new local.
Nov 22, 2009 | NorStar T7208 Corded Phone
Fax rings but machine doesn't answer
First check the setup/configuration and make sure the Fax is set to answer on 1 or 5 rings. If the line is dedicated to fax then it can be set to answer after the first ring. Fax machine works off a modem that listens for the ring and handshake tones. If the machine has been hit with a lightening spike then the hearing portion may be dead.
Translation: Your fax machine is Deaf and can not hear the ring.
It will never answer and do the fax handshake required.
If it is a new machine and still under warranty. Take it back as soon as you can.
If this is a fax machine installed at work.
Be careful, some phone systems used in the corporate buildings have too high a voltage and will fry the modem/fax card.
If this is a home machine with DSL.
Make sure the DSL line filter is applied correctly.
It will be clearly marked Phone or DSL line. Do NOT connect the phone/fax line into the DSL line connection.
Hope this helps!
Nov 08, 2009 | Lexmark X6170 All-In-One InkJet Printer
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
I would like Line 6 on Norstar System to Ring Different
Normal 0 To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
Jan 15, 2009 | NorStar M7310 Corded Phone
Searching for a phone with special feature
Yes you can buy cordless phones with transfer capabilities. We have several of them at where I work.
The unidens are some of the better phones on the market. All we have to do with them is when we receive a call is hit the talk button again and dial the number we wish to send the call to.
Any of the unidens should have this feature you could ask the salesman if you can plug them in to test.
An example of a good phone is:
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2&page=6
Apr 24, 2008 | Northwestern Bell 35828-M2 Cordless Phone
Muted ring tones
my phone seems to be on Mute and I cannot get it off. Help please.
Jan 14, 2008 | NorStar T7208 Corded Phone
Mitel 5220 IP phone won't ring when the main line is ringing
WOW
Ok this post is OLD, but for anyone else having this issue, this is the solution...
There is a programming feature that states: DELAYED RING on certain lines, meaning you can physically see a call coming in to the system (via line flashing), but it will not ring at your desk till something like the 4th ring(hence the name DELAYED ring).
If your set does not ring, and you pick up the heandset, the phone system doesn't know if you want to answer the call -or- you just want to make an outgoing call...
Therefore the Mitel system picks up internal dialtone and waits for you to make the initial reaction (hit 9 for a line out or hit a line that is flashing on the set).
Too change this option, a Mitel Tech is required...
Jan 23, 2007 | Mitel 5220 IP Phone
NorStar M7208 Corded Phone Logo
845 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
