Question about Salomon Absolute Pure Snowboard Binding - Women's
Fastfit straps when changing the fastfit straps, thers a small metal bar with barbs on both ends. getting it in and out takes a while. is there a tool outhere that makes this faster ?
I used a pair of Irwin Vise Grip GV8 X60 Pliers to remove and insert the metal bar in my binding ladders. The binding ladders were fastfit brand, on a Salomon Relay XLT toe strap.
Put one side of the plier on the metal rod and the other side on the opposite side of the ladder and squeeze.
Posted on Jan 09, 2014
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
How do I change the watch strap?
There are typically small pins that hold the band together. There is a special tool to use on metal watches that can be bought
Jul 29, 2014 | Klaus Kobec Womens Couture Leather Watch...
How do i change the assesories that come with dremil how do i use the hand held dremil??
If you have the standard dremel tool ther is a small bar sticking out at the collet end of tool. This is a locking rod to hold motor shaft in place so you can loosen coollet nut. Put pressure on thebar and slowly rotate the shaft until the bar drops in place. There should be a small open end wrench that comes with your tool to loosen nut. If not use asmall wrench to loosen nut.Turn it counter clock wise to loosen. It is not needed to take the nut all the way off. You may have to move tool slighyly to get it to come out.
The tool that you use is determined by what job you are trying to do.Most come with abrasive cut off wheels small grinders,sanders,and polishers.To secure new tool in collet just insert tool shaft in collet and tighten down. When it gets snug then Depress locking bar to finish tightening. Hope this helps you some. Thank you.
May 29, 2011 | General Hand Tools
How do yu remove raymond weil watch strap pins?
It depends on the strap as there are several different types.
But I suspect the one you have has pins that go through the whole metal wrist band.
You need a special tool that pushes out the pin, these normally only come out in one direction.
There should be very small direction arrows on the back of the strap if that is the case.
When putting them back in again they must go in the correct direction.
Look on ebay for wrist watch strap removal tool, looks like a mini vice with a small handle and pin pusher the other end.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Watches
HOW DO I CHANGE THE LEATHER BAND ON THIS WATCH?
The springbars can be retracted using a small tweezers but a springbar tool will make it a much easier job. You can get one from Amazon or ebay for under $5 - search "springbar tool" to find them.
Apr 22, 2010 | Tissot PR50 Sport Chronograph # T34152852...
Is it worth trying to replace battery of my heart rate monitor
You certainly have had good service out of the battery. It is best left to a watch repairer to replace the battery.
Feb 10, 2010 | Polar F4 Heart Rate Monitor Watch
How to take the buckle off the leather strap from cartier leather strap
I will give you the generic answer as I have not actually removed a Cartier buckle. Most buckles use a small bar called a spring bar that goes through the band and "tang". The ends of the bar are like a plunger in that with a small fork like instrument or small screw driver you can collapse the bar and move it out of the clasp. The rest is very obvious. Replacement is the opposite of removal. A fairly simple procedure for most people.
Nov 12, 2009 | Cartier Roadster W62019X6 Wrist Watch
Removing fuel line from fuel filter
Hi, Fuel filters and some other hose connections on vehicles today use a clip mechanism that is easily released with a small plastic tool. These tools are available in most auto parts stores. They come in a set to accommodate different size hoses, and metal barbs. Simply put the longer end of the tool toward the fitting and press to release. Good Luck!
Feb 13, 2009 | 2000 Kia Sportage
WV-57H Watch - how do you replace the strap? I have a new strap for this model and can't work out how to take the old one off and fit the replacement. Thanks
If you look at the watch from the side, you'll see that there's a two-part metal piece on the underside of the watch on each side.  The metal piece is a spring-loaded pin going through the strap which is holding on a larger metal piece.  You need to get another small pin (or an eyeglass screwdriver might work) so you can poke in the end of that spring loaded metal piece, which will allow you to slip off the larger metal bracer.  Then you can poke the spring-loaded pin entirely out of the strap and it will be freed entirely.
To help you visualize what you are doing, the spring-loaded pin operates similarly to a toilet-paper roll - you need to compress the pin so you can slip off the larger metal bit, then take out the pin, which will free the strap.
Oct 30, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How to adjust leather rolex watch band
On the clasp of the watch. There are small holes ware the spring bar sits.
More current models do not have holes that go all the way through on the buckle but the spring bar still sits in between. With a small screw driver press in tward the middle of the strap ware the spring bar sits at the end of the leather strap. Pop out the strap and the spring bar and then place it into the slot that fits.
Oct 14, 2008 | Rolex Day-Date President 118238 Wristwatch
Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
Salomon Absolute Pure Snowboard Binding - Women's Logo
220 people viewed this question
Top Salomon Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Salomon Winter Sport Expert? Answer questions, earn points and help others
