Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
I can't get my camera to flash or work in the "Auto" mode. I've cleared all of the images, reset the settings and use custom settings. I place the camera on "Auto" and turn it on. It goes into the delay mode for 59 seconds and then goes to sleep. It won't take a picture or flash.
3 Suggested Answers
Joe Onley
  • 363 Answers
SOURCE: I-40 camera will not go to picture mode and start taking pictures
Have you done the time/date setup? Online manual says it goes auto after 4 minutes, but perhaps the date/time need to be setup first? Online manual here in case you lost your book :)
http://images.ebsco.com/pob/moultrie/catalog/dgs-i40-user-manual-compressed.pdf
be patient, it takes a bit to load
Posted on Aug 26, 2009
tbreeze47
  • 3083 Answers
SOURCE: My camera is not flashing
It sounds like the capacitor on the flash board isn't charging. They're small electrolytics that go bad in time, but usually are good for a few years. There could also be other problems such as a cracked solder joint on the board. It could also be a fault with the main board, but not likely in this situation.
The unit will have to be serviced, or at least troublshot, and you might contact Moultrie to see what they can do, or what they offer for support. I couldn't find a site for them online, so refer to your manual that came with the unit.
As an alternative, you can run it by a local repair shop, and see what they would fix it for.
Always get an estimate first, since it can run a bit.
Good luck, and hope this helps.
Posted on Jan 02, 2011
Very dark video output and view through the view screen, no matter where the ISO dial is set. The Auto, C1 and C2 mode for Photos is just as dark. I can take good pictures only in P (Program) mode, al
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Dec 20, 2014 | Canon PowerShot G10 Digital Camera
I am using this camera from last 3 years. It was working fine. Suddenly, a problem occurred. Now whenever I select the Auto mode, it is set to video option instead of still image. I have formatted...
I'm have the exact same problem. Purchased the camera 3.5 years ago. Recently needed to shoot a video, when finished I set the camera back to Auto and it stayed in video. Portrait mode shows manual, all other modes work as assigned. I've noticed at least TWO other posters having the same problem within the last couple of months. It's as though this camera (mfg. 2007) has a Trojan program from the factory to make us buy newer models.
Other than resetting, is there a way to flush and reload the firmware?
May 06, 2011 | Canon PowerShot A570 IS Digital Camera
My Canon PowerShot A460 cam is working well until yesterday, the biggest festival here in our place took place. teh flash, the lcd screen, etc is working... but, when i took pictures, the lcd screen turns...
Please try and reset the mode of the image to see if the LCD does not go blank when shown to higher light. Also if there is no issue with the indoor pictures then it is possible that the auto light detection is giving a higher value to reset the image balancing. Shift from Auto to manual mode and try.
Mar 18, 2011 | Canon PowerShot A460 Digital Camera
Hi, the photos i take are getting blurred and the image is not at all clear no matter how shot the distance may be i click the image.the only new icon i see on the screen is vibration warning symbol along...
If you are shooting in Auto mode with flash, this should solve your problem. Make sure you are not dictating any of the settings, i.e. choosing a longer shutter speed, a very small aperture setting, or a very low ISO (sensitivity) setting.
Typically the vibration warning icon will appear when the camera is trying to use a long shutter speed without flash in order to get the right exposure for a darker scene. Your outdoor (bright light) photos are probably OK.
In dim light with a point and shoot camera, you can have your choice between 1. blurry (using a relatively slow shutter speed), 2. dark (using a shorter shutter speed but no flash), or 3. a good photo with flash (which uses a medium shutter speed and added light from the flash)
Mar 12, 2011 | Cameras
I have a Canon Digital EOS Rebel XT and the built-in flash no longer pops up when needed. This started happening after using a Canon speedlite, but then removing it. I've tried resetting everything, and...
In addition to resetting all the camera settings you should also choose the "clear all custom functions" option that is also available from the same menu. Once that's done. Put the camera in Full Auto mode and see if the issue is resolved.
Sai.
Oct 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Blured images when flash not used.
It could be 1 of 2 issues:-
1) Make sure all your settings are on Auto and try again. It may be currently set to a specific scene setting which is distorting your photos.
2) It may require a firmware upgrade. That will involve going to the Nikon website, following links to support/downloads and checking to see if there's an update for your camera.
Apr 10, 2010 | Nikon COOLPIX L20 Digital Camera
All my photos came out blue from my E-500 Olympus
It sounds as if you accidently hit the button for custom white balance setting. It is very easy to do with this camera as this button is located close to the shutter button.
Turn the camera mode dial to the P mode setting. Go to the Menu. Go to the camera 1 tab and then right arrow over and then down arrow to custom reset setting. Right arrow over and highlight reset and press ok. Highlight Yes and press ok. This will reset the camera back to factory settings and should remove the blue from your images.
Apr 05, 2009 | Olympus EVOLT E-500 Digital Camera
Sony Cybershot DSC-H7 - can not change flash settings
for anyone who wants to know how i solved my problem with the flash saying it cannot be changed...
If you go into the camera settings; look under rec mode. It might be in "burst" mode. Flash will only work while in "normal" mode.
Mar 16, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Flash does not work on D 80 Nikon
You will need to upgrade your flash. The salesman was incorrect. Here is Nikon's answer on external strobes: NikonUSA
Kevin
Mar 06, 2008 | Cameras
Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Aug 06, 2007 | Polaroid i832 Digital Camera
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
Top Moultrie Cameras Experts
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
