Question about HP Photosmart C3135 All-In-One InkJet Printer
Need to fix a HP 3135 All-in-one. Print rollers need
Need to fix a HP 3135. Print rollers need replacing.
  • transdink Oct 02, 2009
    I have already done this with alcohol and lint free cloth. It works for about an hour then fails again. This is my second HP printer. I cannot see anyway of even removing these rollers. I have now ordered a Kodak printer. I think the HP mechanism is really inferior. I have seen many HP printers over the past 20 years. They just don't age very well. My printer is about 3 years old and has been used at home, but heavily used.
    Thanks. HP ink cartridges are too expensive anyway.
    Jim
    Thanks. I guess if they were readily repairable, they would cost twice or more. I have an 50 year old Olympia typewriter and it still works just fine.
    Jim
    Scholar:
  • 112 Answers
HP does not make a roller repair kit for that printer (or for any photosmart).
If the rollers are "slick" and not picking up the paper properly you can clean them using a lint-free cloth and distilled water. Rubbing alcohol works well to, but make sure to use a lint-free cloth.
Please let me know if you have any further questions.
Posted on Oct 02, 2009
  • compugrl Oct 02, 2009
    It really is a shame all this equipment is considered "disposable". Have a nice weekend.
My printer hp laserjet 1320 output is light why
The two common things that cause this type of problem are:
1) low toner - remove the toner and shake it from side to side to distribute the toner evenly in the cartridge to test. If the print gets better then you need to get a new toner cartridge because your is almost out.
2) The transfer roller that charges the paper to allow the toner to transfer to the page is worn out and will need to be replaced. The roller is user replaceable and comes in the maintenance roller kit that you can get here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Replacing the rollers takes about 10 minutes or less.
I hope this helps you get your print going again.
BuddyMc
Oct 02, 2012 | HP LaserJet 1320 Printer
Blocked cartridge on my c3150 hp printer
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 07, 2012 | HP Photosmart C3150 Printer
HP-LASERJET PRINTER PROBLEMS   HP-3005 NO PROPAR PRINT OUT      NOSE PROBLEMS
Check one of the followings:
Paper jammed anywhere visible? Rollers, etc?
All the trays are closed properly?
Toner, Drum Unit or the Fuser Unit don't need changing?
See if you can print out the Printer Status of the Printer from it's menu which would give you some statistics of what needs to be replaced etc.
Contact your HP Dealer nearest you to fix that problem, it could still be under warranty so there'll be no added cost to you.
All the best!
ramatau
Jan 29, 2010 | HP LaserJet P3005n Printer
I have a HP laserjet 4P. The print was coming out
You need to replace your transfer roller. Might as well do a complete maintenance kit.(Rollers, Fuser and Transfer Roller)
Nov 08, 2009 | HP LaserJet 4p Printer
Printing appears to reprint on other pages
I have seen several things fix a problems with reprint like yours depending on the spacing between the prints. There is a registration page in the service manual that points likely faults by the distance between reprints. This is based on the diameter of the failed part. Transfer roller, Print cartridge, and the fuser.
Apr 10, 2009 | HP LaserJet 2430tn Printer
HP printer will not feed paper through the rollers
Pick up some Print Roller Cleaner spray, and carefully spray your rollers. As time goes on, fibres from the paper embed in the rollers, which reduce their efficiency to pickup and feed paper. Spray all the rollers and set it dry. You should find that your printer feeds paper. If not, you need a new roller set, available from the HP Spares, or a good local HP Dealer.
Mar 14, 2009 | HP DeskJet 5650 InkJet Printer
Smudged image in HP 8000dn
You need a new TRANSFER ROLLER, it's the spongy roller under the drum.
Jan 16, 2009 | HP LJ-8000DN Laser Printer
Printer keeps jamming
You can order replacement parts and install them yourself or have a repair printer tech do it. But to save money you can do it.
http://www.sparepartswarehouse.com/HP,Photosmart,C6180-All-in-One,Q8181A,Printer,Parts.aspx
I don't have your part number that's on the unit use the link above and put in the right part number. I used Q8181A
What you need is called: HP Printer Belt or Roller: ASSY-PICK ROLLER
Note with heavy printer usage the rollers will wear out quick. If they do the paper will get stuck and jam. In the meantime you can use W40D on the rollers wipe and dry with a cloth that does not have lint. There is a product I use but not so to customer that fixes these problems but it's not the right solution it's better to replace the parts that are bad.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Konika 3135 copier putting dark areas all over copies.
Your a little vag on the problem. The problem is most likely in the drum unit or fixing ass'y. If it Blutchs of toner, it most likely that the small little lip on the developer ass'y is full and needs to be cleaned out. It seats right below the mag roller of the developing ass'y. Or it could be the anti spill mylar under the drum cleaning blade. Need more info. to pin point.
Feb 05, 2008 | Office Equipment & Supplies
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
HP Photosmart C3135 All-In-One InkJet Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
