Question about Roper Dryers
My dryer's timer does not turn the machine off . How do I fix this?
  • 6,784 Answers
This will occur if the timer mechanism becomes faulty or damaged. The timer motor, in this case, is the culprit. Unfortunately, this is not a serviceable part. The entire timer mechanism will need to be replaced, if possible.
Posted on Oct 02, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Tip
What causes my timers to burn out on my washer, dryer and dishwashers
when setting your tmers on your washers, dryers and dishwasher, Do not turn the timer while the machine is in operation. When this happens the timer contacts are arcing and burning. on dishwashers and dryers, Open the door slightly to set the timer. never turn the timers while the machine is in operation. Timers are expensive to replace. If you need to replace a timer, you may consider the cost of a new machine with a warranty. Warranties do not cover timer abuse.
on Jun 08, 2010 | Dishwashers
My lights on my Neptune dryer pulsate and the timer doesnt work properly.
This is a heavy one but I've stated before that all appliances and electronics need a functioning ground----you can't use a 3prong adapter to 2prong----there's no ground for the machine to function by and also an ungrounded machine is dangerous----this may not be your problem but it's the easiest to fix, the cheapest and the safest
Oct 09, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Changing belt maytag legacy dryer sde515dayw model
Have someone else look at the machine, I'm not sure about the last guy. Do smaller loads to ease up on the machine. It will last a lot longer doing more, but smaller loads.
Nov 29, 2013 | Dryers
Dx4500 ge dryer
Maybe the knob is broken and slipping on timer shaft. If not, replace timer.
Sep 10, 2017 | Dryers
Hi - My Kenmore top load stacked washer/dryer has a broken timer. The dryer just goes and goes until it's turned off. Can this be fixed?
you can order a replacement timer from either sears or they do sell a universal timer that can be installed by a service tech timer's run from $35-$90 depending on where you buy it
Jan 12, 2010 | Kenmore 80754 Top Load Stacked Washer /...
The dryer wont turn itself off
Is the timer turning?
Actually, doesn't matter, the timer is the component that turns the dryer on and off. If the dryer won't turn off via the timer then the timer is bad!
(I'm assuming, opening the door turns the dryer off.)
Replace the timer to fix.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool Gas Dryer Timer problem
OK, this timer is designed to spin in both directions and, if you have to advance this timer in any way to complete a cycle, you will need to replace this timer asap.
In most cases, the mechanism will fail, causing this non advancement stage(stalled timer mech).
replacing the timer will fix this issue.
Jun 01, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Aug 29, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
74 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
