Question about Dell E173FP 17" LCD Monitor
Black out in corner of screen is growing
The problem is growing by the day and the monitor is only 2 years old. can i stop the spread?
  • human41 May 11, 2010
    Monitors do die. How long do you use it a day?
  • 44 Answers
If You see that black spot while monitor is off then the LCD needs to be replace. if not then check these....
Check the LCD panel (push a little bit from the black spot place if it loose colours then may be it is due to the improper connection with panel board.( check the voltage while changing the screen resolution, if everything is ok then......
LCD pixels burned. replace the LCD panel or if u want to use it as it is then decrease the brightness and don't use high resolution images.
Posted on Feb 08, 2008
Black "blobs" on PC monitor
hey there I think the problem is your magnet. Make sure to never keep magnets near your laptop. A magnet can erase the data off your disk and cause issues with your monitor. Anything that uses electro-magnetism to function will be affected by magnets.
Cheers mate!
Oct 16, 2017 | Dell Computers & Internet
My screen is having some black spots of about 2cms and its growing day by day , im not sure about the product code but im sure its below 20 inchs. my monitor is abt one and half years old. I'm using...
It is very possible that the LCD is damaged. If the screen was pressed hard enough it can cause the components to become damaged. Repairing monitors is a lot more expensive then buying a new one unfortunately. You probably could get a 22inch monitor for under $180.
May 16, 2011 | Samsung E1720NR 17 inch Monitor
Black spot is growing on my LCD Monitor
It is the LCD itself failing, no repair for the LCD itself, the screen will need to be replaced. Likely cheaper to replace the entitr monitor
Sep 20, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
Sep 18, 2009 | Emerson LC320EM9 32 in. LCD HDTV
15" HP Pav. monitor turns on for a second but immed blacks out
Pls ask your dealer about the warranty..It depends as per the market.. If the light is comming then replace the AD card other wise The problem with the inverter card.. replace ...
Jul 06, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Water damage on left corner black orbs on right corner that continue to grow bigger each day. lines (very thin on screen).
My daugther sprayed cleaner on our vizio tv screen, and now there streaks and a ***** of black pixels at the bottom. Is the tv junk now? Can it be fixed? Will it get worst? Thanks!
Jun 15, 2009 | iLO 3200 32 in. LCD Television
My ViewSonic va1930wm monitor has black spots.
How long have you owned it? Mine did the same thing. It was a dead spot which got worse. It was just past warranty (of course) but I took it back to Home Depot & they worked with me to get it replaced. Unfortunately, I think this is your only hope. The monitor dept. told me that once they get dead spots there is nothing you can do for them. Wish the news was better.
Feb 07, 2009 | ViewSonic VA1930WM LCD Monitor
Blue image growing from corner
Understand I risk getting a bad rating from you, but I thought you should know. You have a bad optical block. Sony was supplying the optical block and covering the labor for replacement until June of this year, but that extension has expired. Your best bet is to contact Sony Customer support at 800-222-SONY. They will probably want an authorized tech to come out and evaluate the set. You may be able to get them to cover the part under warranty, but it may take a letter to the customer service executive committee to get that to happen. I am sorry I could not help more.
Nov 03, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Monitor hit with a Headphone
The black spot can stop or keep spreading, but it will never disappear or reduce in size. This is caused from a leak of liquid between layers inside the lcd panel.
Nothing to do apart changing lcd panel. Bring monitor to nearest service and check if it is worth being repaired (changing screen panel).
Mar 04, 2008 | LG Flatron L1750S 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
362 people viewed this question
Alun Cox
