Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
The pool pump is not turning over, there is power but it sounds like the motor is seized
  • 855 Answers
If you have current and a ground, power wise your fine. You need to check and make sure there is no clogs in the lines causing the pump to fail. If you have no clogs and the pump sounds like it is trying to work, it probablly is seized up and needs replaced.
Posted on Oct 02, 2009
Pool pump making a buzzing sound when the power is turned on . pump will not run.electrical breaker pops when i turn it on.
Hi Frank, that sounds like the pump motor may be jammed. sometimes things rust or corrode and eventually seize up.
Pull the pump and check it.
Jan 23, 2015 | Pool & Spa
Pump making a buzz noise but won't start up
it sounds like the motor has seized. if not seized, there may be something blocking the impeller. disconnect the power and try to spin the impeller
Sep 10, 2014 | Hayward Pool & Spa
I have Hayward (A O Smith) 1.5 hp pool pump c48l2n134b3, was makeing loud noise, but today stopped working and is making sound like zzzzzzzzzzzzzzzz sound, but not pumping or working. Do i need a new...
sounds like a seized bearing. they can be replaced at your local motor shop or pool store. now that its buzzing, i would also suggest getting the start capacitor replaced at the same time.
Oct 05, 2013 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a Jandy stealth series pump and this morning it was not running. The breaker was tripped and when I reset it and turned it on the motor only hums for a few seconds and then the breaker trips...
This sounds like the motor has seized up. You will most likely need to replace at least the motor and maybe the complete pump assembly.
You can take the pump into a local motor shop and see if they can rebuild the motor for you.
US Parts Center
Aug 21, 2011 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
We just turned on pump, was on for about 30 seconds, hummed, did not come on and pump got hot. any suggestions
This sounds like a frozen (seized) machine. Is the impeller able to turn? If the impeller is locked, maybe you can release it. If not, you may need to haul the unit to an electric motor shop, for repair. Some more powerful motors use a start up system, some mechanical, some use condencers (sometimes called starters), and at that point, you want to be SURE what is needed, for safety.
Hope this helps.
May 22, 2011 | Hayward Super Pump 1 1/2 - Hp for In...
My AO Smith motor sounds like it is jammed. When the pump starts you can hear the motor buzz but it wont actually turn on. then after about 5-10 seconds the put shuts completely off. I replaced this pump...
sounds like jammed or bearing seized water could have seized bearing spray and lube bearings than try by hand [with a non marring pliers or if can grab impeller] and try to turn motor by hand to loosen motor-- when motor doesnt turn it heats up and will turn off till it cools down this is a safety u may get lucky and the motor will run if it hasnt shorted out a winding
Jan 20, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Pool motor makes a buzzing sound but doesn't work
sounds like it has a bad capictor .. look fr a otor shop in your area that tsts them , should be free test
May 30, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I replaced the shaft seal today and the pump motor is getting hot and shutting off every 30 seconds or so. The motor is making a wineing sound and no pressure is comming up on the filter.
The motor is not turning, either due to a seized impeller or bearing. Check for free spinning of the motor and impeller by hand. If ok, then look for a bad starter capacitor or defective primary/secondary motor switch assembly
Apr 16, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
314 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
