Question about Jenn-Air JJW9830D Electric Double Oven
How do I adjust the hinges on a Jenn Air double wall oven to keep the bottom oven door closed
  • 1314 Answers
SOURCE: Jenn-Air single electric wall oven #JJW9530DDS
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
Posted on Dec 29, 2007
SOURCE: oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Posted on Jan 18, 2008
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
reg501
  • 413 Answers
SOURCE: jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Posted on Jun 10, 2008
lsteward68
  • 331 Answers
SOURCE: My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Posted on Apr 27, 2009
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
The oven doors won't close and hot air is blowing out of the lower oven under the bottom of the door
Could be weak door hinge springs, there is no adjustment provided, normally only solution is to replace the door hinges
You may find the following link helpful.
If you find it helps, please leave positive feedback.
Thankyou.
Jan 25, 2010 | Jenn-Air JJW8230D Electric Double Oven
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
One of the oven doors does not close tight so heat escapes. It is a Jenn Aire electric double wall oven model number JJW9627DDS.
Sounds like the oven door hinges have worn. If door is not obstructed in any way and will fully close when pushed but open about half a inch when released then it will be the hinges. Not sure of cost of spairs. I believe this to be a John Lewis Model. If it has a Enr no inside the door or inbetween the door hinges then I could give you price on spares
Nov 15, 2009 | Jenn-Air JJW8230D Electric Double Oven
Doors don't shut all the way and light stays on
It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
Sep 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven door does not close
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW9830D Electric Double Oven Logo
207 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
