Question about HP LaserJet 4000n Printer
Paper jam in rear door and dont know how to find it
  • sampling336 Oct 02, 2009
    Dont know where the fuser is!
    Scholar:
  • 96 Answers
Can you remove the fuser? if i remember correctly there is a switch or flag under the fuser that sometimes does not reset properly. by removing the fuser it should reset and check the rest of the paper path.
Posted on Oct 02, 2009
SOURCE: Canon MP830 paper jam
Your "Best Solution" posted 10/01/07 needs just a little bit more. I followed the directions and saw the jammed paper but couldn't get hold of it. I then called Canon support and they told me that the green plastic can be pulled up and then the paper under it is accessible. I pulled up the green plastic and was able to grab the jammed paper and pull it out. He also told me that the solution could be found in the Canon knowledgebase with a color picture as well.
Posted on Feb 04, 2008
SOURCE: paper jam
Probably one of the sensors on the fuser is not working correctly. There are two sensors on the back of the fuser that move when the paper exits the fuser. Remove the back of the printer when the printer says there is a jam and move the sensors to see if the error goes away. If so you may have to replace the fuser unless you can just replace the defective sensor.
Roger
Posted on Jun 17, 2009
SOURCE: 202 Paper Jam
A 202 error usually means that there is a problem with the fuser, more than likely the fuser exit sensor is jammed - either with a piece of paper, or the return spring on the sensor has stuck. Check this sensor, making sure it can return to the upright position freely. This should clear the problem. If it doesn't, or the sensor arm is broken, a new fuser should solve this problem
Posted on Jul 17, 2009
  • 97 Answers
SOURCE: Lexmark T642 display says paper jam check rear
The sensor in the fuser unit is jammed/broken. The fuser will need to be repaired or replaced.
Posted on Aug 13, 2009
Testimonial: "Thanks for that-I thought I was going mad. I'm not sure about getting it repaired as it may be cheaper to buy a new one."
SOURCE: 202 Paper Jam Open Rear Door
I had this same problem.... I put a new toner cartridge in it and it worked fine.
Posted on May 25, 2010
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
I have a paper jam i cannot find on a kyrocea fs-1300d any suggestions how to find and correct this problem?
Hi
1. Paper jammed can be found in the paper tray. Just remove all the paper and inspect paper jammed from the feeder roller.
2. Paper jammed can be found in the toner cartridge compartment. Remove the toner cartridge and inspect for paper jammed.
3. Paper jammed can also be found in the rear door of the printer (back door of the print). Check if there is a back door and inspect for a paper jammed into the roller.
4. Paper jammed can be found in the toner cartridge itself. Check for teared paper inside the toner cartridge.
Please let me know if you need more help
Mar 05, 2011 | Kyocera Fs-1300d Printer
While printing 2 or 3 lines it shows paper jam message. Can't print even a page!!!
make sure you don't have any small pieces of paper stuck in the printer s.gif s.gif s.gif
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door c00108288.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Jan 10, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Printer says to clear paper jam and press OK there is no paper jam
If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not
in the rear rollers, check the top door.
To clear a paper jam from the rear door
1. Turn off the HP All-in-One.
2. Press in the tab on the rear door to release the door. Remove the door by pulling it
away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Page 148 of manual here will show you more info as well as photos on hoto.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 01, 2010 | HP Photosmart C8180 All-in-One InkJet...
Says Paper Jam But No Paper In It
Hi
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door bd842f6.jpg
  5. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  6. From the rear access door opening, remove the jammed paper.
  7. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  8. Reinstall the rear access door.
  9. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • When loading paper in to the paper tray, push it in until it meets first resistance. Do not continue pushing the paper in. If the paper is pushed too far in, more than one page is picked and paper jams result. This is the most common cause of paper jams with the HP Officejet 410 series.
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once, replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months - one year, clean the paper feed rollers with a rag slightly dampened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | HP Officejet 4110 All-In-One InkJet...
HP ALL IN ONE PRINTER
Follow these steps to clear paper jam
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
Jun 19, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
CAUTION:
Jun 10, 2008 | HP OfficeJet 4255 All-In-One InkJet...
My paper keeps jamming
Clearing paper jams Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
  1. Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
  2. Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you. NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems. Figure 1: Rear access door c00101861.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
    • If under warranty, contact HP to obtain a replacement part.
    • Click How to buy on this page to order replacement parts.
  3. From the rear access door opening, gently pull the jammed paper free.
  4. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray. Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
  5. Reattach the rear access door by inserting the two pins on the right of the door into the holes for them (as shown in Figure 3 below) and then pressing in gently but firmly on the left side. Figure 2: Inserting the rear access door guide pins into the holes c00099183.bmp
  6. Reconnect the power cord to the unit and turn the unit on.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Fax Jam
hp tells me to do the following
does this help you ?
Issue While printing, copying, or receiving a fax, a paper jam occurs. If the jammed paper is removed incorrectly, other problems may occur. Clearing paper jams Remove the jammed paper by following the steps below: WARNING: Jammed paper must be removed using the rear access door to avoid mechanical damage. Do not remove jammed paper from the front of the all-in-one.
  1. Turn off the HP product and turn it so the back of the all-in-one faces you.
  2. Disconnect the power cord from the back of the all-in-one. CAUTION: The power cord must be disconnected to allow the paper feed rollers to turn freely and avoid mechanical damage.
  3. Locate and open the rear access door by pressing in on the left side tab to release the catches and then pulling the door toward you. Figure 1: Removing the rear access door c00100775.jpg
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  8. Reconnect the power cord and turn on the all-in-one.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with fresh paper.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
richard from chicago
Dec 02, 2007 | HP Officejet 5510 All-In-One Thermal...
HP LaserJet 4000n Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
