Question about HP PSC 750 All-In-One InkJet Printer
Printer cartridge error,then scanner failure...
My printer goes from black printer cartridge error to scanner failure. It will not print anything. I have called HP and stepped through their trouble shooting with their tech. They tell me it's hardware. I'm not totally convinced
  • 4 more comments
  • Ninilynn Jan 03, 2008
    I can not print anything. I get scanner fauilure no ink problem. Have deleted printer and reinstalled. Have been on hp downloads no help. Have unpluged done everything. I don't belive it is a hardware problem.. I still belive it is software. It also tells me on menu scanner option not set
  • MsMaam75 Apr 27, 2008
    when trying to align new printer cartridge or trying to scan a document; the error msg :scanner failure, turn printer off then back on. THIS DOES NOT CORRECT THE PROBLEM. What to do?
  • Bamakopete May 26, 2008
    My 750 prints when it wants to. As soon as it powers up it goes to scanner failure. If you can get the scanner program open before the scanner failure comes up, it says scanner failed to initiate.
  • emmett11us Jun 22, 2008
    error message cartirdge carriage jam
  • goldgrey Jul 14, 2008
    incorrect black cartridge
  • menorca Aug 02, 2008
    Hi my printer goes from wrong black cartridge installed then to scanner failure tried cleaning head as you suggested but still the same, any ideas
My printer is say "instrucciones para alinear cartuchos de imperion"
Posted on Jan 03, 2008
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 07, 2010 | Dell A960 All-In-One InkJet Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
color cartridge.
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
"Cartridge Error: Cart. on left is not intended for this printer"
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9o15
Apr 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cartridge Aligment Failure
Then printer successfully printed alligment page you must to put this list on scanner glass to confimation and calibration of printing heads and press "Start or OK", without this part of procedure yours printer will be show error message.
Aug 29, 2008 | HP 190 Copier
DELLA 940 DOES NOT PRINT
Hi there Error 50c
color cartridge.
Jul 20, 2008 | Dell A940 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Cartridge Error
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
176 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
