Question about Fuji FinePix S1000FD Digital Camera
The screen is white no discplay. No physical
The screen is white no discplay. No physical damage
White pixels nec np100
Your DLP chip is damage or getting to been damage.
** To make it sure you can do it your self by getting some basic tools such as proper screw drive, and open your projector for parts.
And you can physically observe the Chip.
Please check by side angle on the chip surface. **
Feb 14, 2014 | Optoma DLP Projector Multimedia Projector
Screen on my Coby Kyros Tablet just stays white. Nothing appears to be operationally except for the ALARM . Model# MID7048
it would have to be replaced, as it seems there is some physical damage if the screen is white.
Apr 11, 2013 | Tablets & eReaders
Error de mispatch when i changed the discplay
1. Check all connections
2. You used the wrong type of display
Jul 03, 2012 | Lexmark T644 Laser Printer
A white screen is in the middle of the screen and blocking everything the laptop was cold when I turned it on now it is changing colors
white screen indicate the patch on the display possibly either display is physically or internally damaged....if its a software fault try reinstalling the video drivers...it may help else u can contact the manufacturer for service
Feb 13, 2012 | Toshiba Computers & Internet
My TV falls down from table and now it has some static white lines everywhere.no physical damage.half screen missing unable to see.
There is most likely physical damage inside the monitor, it may be as simple as a connector needing to be reseated or reconnected. If you aren't competent to undo the monitor and inspect find someone who can undo it and inspect for physical damage. It will most likely be obvious once you inspect. If it is the connector to the screen you may have to scrap the monitor.
Regards
Sep 12, 2011 | Samsung T220HD LCD Monitor
Thin white line on ipod classic screen
It's probably caused by damage of the tape that connects screen to the main chip. If it isn't damaged by physical shock you can try replacing it in Apple Store
Mar 02, 2011 | Audio Players & Recorders
White Screen
sounds like a faulty monitor,time for a new one,is it under warantee???
Aug 16, 2009 | Dell SE198WFP LCD Monitor
My motorola razr v3 screen keeps going all white!?!
first, make sure your Razr has no physical or water damage. If it's a T-Mobile phone, there will be a red sticker on the phone behind the battery. That indicates the phone as been exposed to water damage. Could mean the phone is shorting out on you. Now, I would suggest if the is NOT water damaged, to powercycle (turn off and on the phone) daily. Just off for about 30 seconds. Not long at all. If the white screen continues, do a master reset. Settings, -intial set up-master reset-code is 1234 or if you put in a different security code.
This will work!
Jan 29, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Physical damage to lcd screen
I have TCL LCD TV 32E61
Dispaly problem in Centre White line
Dec 09, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Fuji FinePix S1000FD Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
