Question about Epson Stylus C46 InkJet Printer
I have epson C46 printer installed .my opsystem is windows vista SP1 .I cannot find access to printer settings
SOURCE: cant install epson c46 printer on vista
I have just got my epson stylus C46 working by just plugging in the USB from the printer and turning the printer on. I didn't download any drivers, vista searches and downloads a compatible driver for you when you plug it in.
You may need to make it your default printer by going to control panel, printers, then right click on your epson and make it the default.
Hope this works for you as it did for me!
Posted on Oct 23, 2007
SOURCE: old epson stylus c46
Yep! Go to www.epson.com and follow instructions for download.
I use XP so go here. http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=dkmEK02SU002Fer6qudElZT5RHsMyD4iBT1M
Posted on Feb 19, 2008
Joed911
  • 4338 Answers
SOURCE: C46 printer
I could not find the manual, but I hope this helps:
I'm not sure if the waste ink pads are in the same place as the c45, but i hope this helps.
Locating the waste ink pads was pretty easy. First of all you have to dissasemble the case, then remove the paper slot. To do this you have to unscrew three or four screws (at least in my c45) that keep the paper slot attached to the printer. After doing this you will see the ink pads, they are at the bottom back of the printer. Mine has four of them with an "L" alike shape.
Clean them with plain water, then let them dry a couple of hours until all the moisture is gone.
I advice you to remove both ink cartidges before doing this because an strange thing happened to me.
After removing the ink pads i cleaned the ink pad container (you'll see the little tube that drains the "waste" ink from the cartidges to the pads) then a couple of hours later i found that the container was full of ink!! confused1.gif . And of course, the ink cartidges were almost empty upset.gif
That happened because i didn't remove the ink cartidges before doing the whole process. I have no idea why that happened but probably by removing them you'll avoid that.
Epson resetter software can be found at http://www.ssclg.com/epsone.shtml (the link to download it is located at the bottom of the page)
One last thing, to reset the waste ink counter you have to go to "Protection Counter" menu and then click "Reset Protection Counter".
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
  • 90 Answers
SOURCE: epson stylus c46
Go here: http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20C46-_E
You can get the user guide as well as a setup guide.  If this helps please rate my solution.  Thanks
Posted on Dec 11, 2008
sabharish
  • 297 Answers
SOURCE: I have lost the installation disk for the epson c46
You can get the driver for Epson Stylus C46 InkJet Printer in the below link
http://driverscollection.com/H=STYLUS%20C46&By=Epson
Posted on Mar 29, 2009
I have lost my cd for installation for epson stylus c46
You can download the installation driver and software from manufacturer's site by clicking this link
  • On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu and download the required drivers and software.
Hope this solves your problem. Thanks for using FixYa.
May 08, 2010 | Epson Stylus C46 InkJet Printer
I cant install my printer lost C.D.
You can download the installation drivers and software from manufacturer's site by clicking this link
  • On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) and download the drivers and software.
Apr 18, 2010 | Epson Stylus C46 InkJet Printer
Lost install disk cant istall after pc repair
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Epson Stylus C46 : Drivers & Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,doubleclick on the file, then if you get introubles,follow theinstructionsbelow to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
Epson c46
Here is the link :
Unplug printer USB before starting driver installation.
Note : Vista drivers are not available for this printer.
HOW TO INSTALL MY EPSON STYLUS PHOTO R200 I DONT HAVE THE DISK OR CD AND I HAVE WINDOWS VISTA
Try visiting Epson website...look for support link for drivers...then find your printer and operating system...download drivers and install....install program should provide directions..generally it will direct you to make sure printer cable is not connected to pc until install program tells you to do so. You can also do a google search for "epson stylus photo r200 drivers for vista", chances are you'll find a site from the results...good luck
May 22, 2008 | Epson Stylus C46 InkJet Printer
C46 epson printer
connect to PC through usb, plug it on, if OS is WIN 98 install the software manually, if XP it'll install automatically. print a test page, calibrate ant enjoy....................
Jan 11, 2008 | Epson Stylus C46 InkJet Printer
I have not a CD for installation of Epson Stylus C46 I tink you ,
go to the following link
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84W2LhUcmWnHiUk31CNK52sUU003D
Select inkjet printer in product range
THEN
Select Stylus C46 in printer
THEN
Select you operating system
THEN
Click on Confirm Selection
You should have access to download the manuals and software that would have appeared on the CD.
Dec 11, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
16 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
