Question about Starrett Saws
Circular saw motor wiring diagram - Starrett Saws
I need the wiring diagram where the they on the switch and saftey switch Where the white, black and red wires go on the red trigger switch
Posted on Oct 02, 2009
4 Suggested Answers
  • 313 Answers
SOURCE: Switch diagram
as u notice the terminal on the switch has 2 connection like a switch diagram to it.it has normally open & normally close contact. the normally close contact are for red & white wire & the other
contact are for 2 black wire which is normally open contact.hope it helps.
Posted on Sep 19, 2008
  • 497 Answers
SOURCE: craftsman 7.5in. circular saw model #31511880.
Is this a brushless motor?
Posted on Nov 06, 2009
jeff_drakesr
  • 155 Answers
SOURCE: B&D Corded Circular Saw - Arbor Does Not Move
This model is not equipped with a clutch so its possible that the gears are stripped, shaft broken. If the blade moves freely then this is probably the case. If blade does not move freely, check for any foreign objects between blade and blade housing. I hope this has helped if you have any further questions don't hesitate to ask. Please rate on the helpfulness of the answer. Good Luck and have a great weekend.
Posted on Apr 04, 2010
Testimonial: "Thank you for your prompt response. My B&D Circ Saw Model is 7301-Type2. I will try your recommendation. Will keep you posted. Thanks again."
I have a Milwaukee circular saw, 6365, and am replacing the switch. Need a wiring diagram!
Scott,
What is the serial number on your saw? I need that to make sure I get the correct info for you.
May 30, 2015 | Milwaukee Tool Saws
Lumber wiring diagram
Lumber - a piece of wood , wiring diagram ! would you like to try again ? I know for a fact there is no lumber wiring diagram on a 1999 Cadillac Deville !!!!!!!!!
Apr 19, 2015 | Saws
How to get motor out of houseing on a makita 5007MG circular saw
The armature and field will need to come out. It's quite a bit of work to swap everything over. Here is a parts diagram which should help.
Makita 5007MG diagram
Aug 06, 2012 | Makita 5007MG Factory Reconditioned 7 14...
Need to replace the cord. Before I open it up, wanted to verify that it has serveceable connectors inside?
generally they have ring terminals on the switch or the wires need to be soldered to be pushed into and lock into the switch. ON some rare occasions I have seen wire nuts, so you should be OKAY just make yourself a wiring diagram before removing anything, it makes reassembly easier.
Aug 01, 2011 | Porter Cable 345 6" Circular Saw Saw Boss
Motor runs, saw not cutting
Hi
If motor is running and the blade is not turnning the motor pinion gear is damage.
Go see this link for parts diagram.
http://www.ereplacementparts.com/skil-5500-f012550000-714-circular-saw-parts-c-130_160_843.html
Feb 07, 2011 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
I have the Hitachi cordless circular saw (C18DL) after a good year of use it has stopped working, when I press the trigger the light comes on but the blade does not move and the motor does'nt make a sound,...
It will be the brush holder in the motor has broken.......Ive just had my 4th brush holder break up, The design of them is rubbish!
Im planning on making a hole on the motor casing to accept proper brushes, Ive taken them apart and replaced the broken brush with one out of another motor and bought a faulty one for the brush holder.
Dec 04, 2010 | Hitachi C18dl 18v Cordless Circular...
Need wiring diagram to check continuity on trigger switchfor makita 2400b
If you cannot find wireing diagram,just have the saw unplugged and take one of the wires connected to the trigger off. Then by useing an ohm meter you can check for continuity.
Feb 21, 2010 | Makita 10" Miter Saw LS1030N
Wiring diagram needed for D.O.L. motor starter
how can i connect a level switch with relay operation between motor and dol starter for bothe single phase and three phase
Oct 04, 2009 | Craftsman Saws
Switch diagram
Be careful with your wiring as some models have a reset switch. Your best bet is to mount new external metal boxes to the frame and obtain industrial switches capable of carring the amperage load that the motors are drawing. Then you'l have identical controls on all units so future control problems will be esasy to solve. In your wiring, always remember that the black is the hot side and always routes through the switch and then to the motor while the white bypasses the switch and goes direct to the motor. In event you have a reset switch,, your black will go in as well as out of the reset and then through the switch to the motor.
Hope this helps.
Apr 06, 2008 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
588 people viewed this question
Top Starrett Saws Experts
Tom Chichester
ray gallant
Are you a Starrett Saw Expert? Answer questions, earn points and help others
