Question about Sony Playstation 3 (PS3) Console
When i try to connect to the internet, it stays fails in 'obtaiing ip adsress'??
  • 139 Answers
If you go through a router unplug modem and router wait about 2 or 3 minutes plug modem back in first wait about one minute then plug router back in and then try to hook up online.
Posted on Oct 02, 2009
BD-P1500XAA won't connect to the internet for up dates.my internet services provider said that my connection is ok. I plug in to the lan port and turn on dvd press menu and dvd go to set up, press enter...
My suggestions :
1. Try to test your internet connection on menu setup after you set IP address.
2. If it failed, switch you connection to auto. Than test again.
3. If all method above is OK, try to update firmware from USB.
Feb 28, 2011 | Samsung BD-P1500 Blu-Ray Player
Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED] *** 'COMPONENT_TYPE_WININET' value:...
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
Aug 16, 2010 | Yahoo Messenger
I am having trouble staying connected to the internet wirelessly. I put in the correct WEP password and start out having full strength bars but then it says that i am not connected to the internet (a...
If you are using a wireless connection.. It is always advisable to disable the firewall setting.. Please do that so your connection will be stable...
If connection failed or disconnect try repairing your ip address...How?.. on the lower right portion of your desktop in the taskbar you will see 2 small icons of monitors... right click on this... then click "repair" Do this always if connection failed.
Hope this help you..
Much appreciated if you rate this help...thanks
May 22, 2010 | Linksys WRT160N Wireless Router
Netgear Random Internet Loss
have you tried setting a static ip address?
Sep 09, 2009 | NetGear WGR614 Router
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Can't get network connection to work.
Are you trying to connect to the Internet using a wireless router or vai a network cable?
Have you got an Internet Service Provider and does your computer have trouble connecting to the Internet?
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Internet connection failed but IP address obtained.
sounds to me like you have the security turned on . Just type in your security key on PS3 and it should connect. Best of luck!
Jan 11, 2009 | Video Game Consoles & Games
I try to connect my ps3 to the internet wirelessly and have probs
Hmm, try setting it closer to your router. Ya know the box that has the wireless internet in it. It might not be getting a strong enough connection.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
