Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Cant connect my wireless headphone to my lcd tv?
I just got a wireless headphone but i cant connect to my lcd tv, in the back of the tv,there's no output so how can i connect it?
    Sergeant:
  • 199 Answers
Hi,only through a Music system   because the TV has no port  unless u want to temper with the mother board  of the set .
This is the easiest  method  for u to enjoy ur headphones coz music systems has the headphone jack pin  socket .
good luck
Posted on Oct 02, 2009
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
This is not a problem, but does the model: Toshiba 26AV52R have a headphones plug-in?
Hello, you can connect wireless headphones, sound output to TV. Connections are usually RCA connections or SCARET
Apr 22, 2011 | Toshiba 26AV52R LCD TV
I want to connect wireless head phones with my Panasonic LCD TV (Model#: TH-L32X9D). There's no additional Headphone slot. So how can I use the wireless headphones. Also is there any way to switch TV...
Most TVs these days do not come with headphone out jacks. If your TV has RCA audio out, you can get a RCA to Headphone jack.
If your TV has no audio outputs at all, you're out of luck.
If your TV is equipped with audio out, there will be an option in the speaker or sound menu of your tv to turn off internal speakers and transmit directly to external speakers. If there is no audio out on your tv, this will not be an option.
Mar 11, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Is there a way to use headphones on the 32" TV Model #VX32L HDTV1
You can purchase wireless headphones at most electronic retailers. They will connect to the stereo RCA outputs on the back of the TV. Then you just turn the volume down on the TV. I hope this was helpful, best wishes.
Apr 26, 2010 | Vizio L32 32 in. LCD HDTV
How to connect my wireless headphone to a Panasonic LCD TV, there is only a single earphone jack mine has got 2 plugs
That's a new one, 2 plugs would indicate seperate audio ( right and left ) or 4 . Try this go to RadioShack and buy a Y that you can plug both plugs into and then plug the single plug into the TV jack. Look at the plugs on the headphone sender do the plugs have a single band or double? If single use above solution, if double just plug 1 plug in.Good Luck.
Sep 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Want a TV wireless headphone with no headphone jack or audio out
You may have to connect the headset through a VCR or DVD player that does have the output connections.
Sep 05, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
My Proscan 32LB30QD does not have Audio Out! Is there a way to connect a wireless headphone to this TV?
You can either see if your cable box (if you have one) has RCA outputs on the back or if you are using some sort of a VCR or DVD it should have audio outputs on the back. The only problem with the latter hookup is that you have to turn the vcr on if you want to hear thru the headphones.
Aug 07, 2009 | Proscan 32LB30QD 32 in. LCD TV
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
209 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
