Question about Casio FX-9750GPlus Calculator
How to get line of best fit - Casio FX-9750GPlus Calculator
  • Casio Master
  • 8,064 Answers
Once you enter your data [MENU][STAT], press [F1:Graph], select Gph1, Gph2, or Gph3. Once the graph of the experimental data is drawn, you will have access to the diverse regression models. Your choices are [X:Linear] [Med-Med], [Quadratic :X^2] [Cubic;X^3] [Quartic: X^2]. Press [F6] to scroll right to access the others: [Logarithmic:LOG], [Exponential :EXP], [Power :Pwr] and [Sinusoidal: Sin]
After you select a model and press [EXE], the screen displays the equation and its various coefficients. On that same screen, you have a menu option [F6:Draw]. If you select it, the regression curve will be drawn on the same screen as your statistical graph. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
Hope it helps.
Posted on Oct 02, 2009
Install new fuel line
Ryobi makes a great little kit for fuel lines its not expensive and it fits most small engines (less 46 cc) like weed whackers and chain saws , it includes a "TOOL!!!" for feeding new fuel lines thru and of course has new fuel line too , this tool is invaluable in getting these things to fit , and its got some neat directions on how to use it , best of all it fits lots of makes and models too
Apr 29, 2014 | Poulan 18" Wild Thing Chainsaw
When i change my original air box 2 cold air what do i do with the 2small vacume lines 2 the original air box?
best thing to do is find a way to connect the vacuum lines to the new cold air intake. best way is probably drill a hole is pipe and tack on or silver solder some little air fittings for the vacuum lines to fit onto, otherwise you can do it the bodge way and just drill tight fit holes in the pipe so the hose push tight into it.
Mar 14, 2011 | Volkswagen Jetta Cars & Trucks
Can not get fuel filter loose
The lines and fitting are so rusted it is advisable to replace the lines and fitting completely. The fittings are made of steel and the filter is all stainless steel. Tubing wrenches are best to use to try and remove these fittings. If not possible replace the fuel lines with compression fittings at the cut ends with the appropriate fittings at each end to fit the filter
May 23, 2010 | 2000 GMC New Sierra 1500
Need a diagram on how to connect the fuel lines back on a ryobi 725r trimmer
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Oct 01, 2009 | Garden
Routing of fuel lines
Typical fuel line routing2.gif is:
Oct 01, 2009 | Craftsman Convertible 14" Gas Line Trimmer
How to connect gas hoses
Sep 29, 2009 | Garden
Fuel line routing for RYOBI Models 705r and 725r
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Garden
Troybuilt 2 cycle fuel line routing
Sep 04, 2009 | Garden
Replaced gas lines on ryobi 31ccweedeater. my have lines crossed. will not crank.
One fuel line (the one with the fuel filter in the end of it), comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to the top fitting on carburator. That should be the correct fuel line routing. Hope this helped and best wishes.
Aug 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The line going into the trans from the raiditor tha line leak so much i lose a qurt of fluid a day i think its a fitting into tha trans cuz the line is loose wat should i do?
The transmission cooler lines (2) screw into a fitting on the transmission. Best to use a line wrench to tighten the fitting, lessen the chance of stripping. Hope this helps
May 11, 2009 | Oldsmobile Cutlass Supreme Cars & Trucks
Casio FX-9750GPlus Calculator Logo
687 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
