Question about Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver
The speakers are shorted
I plug it to a 220 volts
    Guru:
  • 389 Answers
See power fuze
Posted on Oct 02, 2009
Will American power tool batteries work after being plugged into a 220 charger
Yep. they will as long as the 220 volt charger was connected to 220. If a 220 volt charger is plugged into 110 volts it may not charge the battery but no damage to the battery will happen.
Dec 04, 2014 | Drills
WhAT HAPPENS IF I plug a 110 volt machine to a 220 outlet
Normally the plug connector would not fit, they are different. But for some reason, if you have one that takes 110 and you plug it into 220, there will be af ire. You will burn through the circuits immediately and short the entire thing out at every solder point. The real problem is the wattage. The watts are pushed with 220 volts of fource, which will fry your 110 setup.
Sep 27, 2012 | Olympus HPU-20 Cautery Unit
Hi with regards to my audio a7x monitor speaker... on the unit it says 2 options 220-240V 50hz 100-120V 60hz IT says use only with a 250v plug.. which i did:/ the speaker just doesnt turn on at all?...
You must switch the voltage option to match the mains voltage in your area.
If you have 220 or 240 AC volts mains voltage in your area and you have set the switch on your monitor speaker to 100-120 volts and then connect it to the mains supply then you have destroyed your speaker.
Mar 14, 2011 | Audio Players & Recorders
110volt or 220 volt are in use for this speaker
if u got the speakers from countries which use 110 u have it with 110 and if u got it from countries using 220 u have it with 220 capability
Feb 01, 2011 | Labtec LCS 2424 Computer Speakers
I plugged my 110 volts Altec Lansing speakers into 220 volts :( How can I fix it? Please help me. Thank You.
Check fuse, but if there wasn't a fuse , your Altec need repaired to fix broken components in power circuits, could be the resistors, diodes or even transformer.
Jul 03, 2010 | Altec Lansing BX1020 Computer Speakers
I plugged power supply into 220 volt. do you
check out for the main fuse in system, and if you have 110v, rating..then the transfomer for the device is damaged, just replace the transfomer and on the system again..the whole system is not damaged, could be the transfomer, and the fuse.
Oct 25, 2009 | Boston Acoustics MicroMedia Computer...
Plugged an american computer speaker set into a uk plug and it turned off. will not turn back on. blown fuse or is entire set dead? is it possible to simply change the fuse and replace with voltage...
USA = 110 Volts AC
UK = 220 Volts AC
If there is a fuse, you will find a piece of toast in its place
How did you manage this in the first place, the plugs are dramatically different. You fix this yourself?
You might be better off with a new speaker. If the power got through, it probably smoked your transformer.
Oct 12, 2009 | Logitech X-530 Computer Speakers
The power supply of my pioner dvd was burn
Hi
check all semiconductor in the power board and look for a shorted and open parts! then replaced the defective parts.
Thanks!
Dec 05, 2008 | Televison & Video
AWR1-1W
It will Blow up :D Short out the transformer with some nice smoke out the back, its a very expensive machine and i wouldnt advise that.
Dec 02, 2007 | Bose Wave Radio
Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
239 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
