Question about Brother MFC 7420 All-In-One Laser Printer
Back door open
"back cover open" display but is closed
    President:
  • 2,306 Answers
Inside the back door is a black plastic guide, in the center there's a lever that moves when paper goes thru, on the right is a flag that needs to be in between the horseshoe shaped sensor on the right. Make sure the lever moves freely...
Posted on Oct 02, 2009
  • Timbo Jul 26, 2011
    There lever is attached to a skinny black rod, rather fragile. It should move freely. it can get bumped out of place when you remove a paper jam. You can remove the gray plastic guide first, without tools. Be gentle! Then you can remove the black plastic guide and gently jiggle the black rod with lever and flag back into place. Worked for me! Good luck.
Jammed paper seen when back cover opened, remove it and ok!
Posted on Oct 03, 2009
Oven light on display says door and now wont heat
The oven will not turn on the heat because it thinks the door is still open. It thinks the door is open because it has a sensor that gets pressed by the door when it closes (look around edges of oven that get covered when door closes) this sensor is wet, dirty or broken so when you close the door the sensor still says its open. Did you clean around the door with a wet cleaning fluid?
Dec 20, 2013 | Whirlpool GBS307PRS Stainless Steel...
Westinghouse wse6070sb*5 front display reseting when door opens or closes
Youmost likely have a bad connection of the wires at the top of the door where there hinge cover is you need to remove the hinge cover and check that plug that connects the wiring to the door or you have a broken wire
Appliance 911 Sea Breeze
Jun 27, 2012 | Refrigerators
Printer quit printing. Screen says fuser cover is open. Where is it located so I can close it?
Your problem: paper is jammed in the back of the printer around/in the fuser.
The Users Manual for your printer is located at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users Manual/UM_DCP_7030_7040_EN_1510.PDF
You'll need Adobe Acrobat Reader (free from www.adobe.com) to view it.
LOCATION:The fuser cover is located in the back - its covered by the panel in the back called
the "back cover" aka "back output tray cover".
2-step fix:
(A) open the back cover - on the back of the printer.
HOW: it flips down
(B) open the fuser cover and remove paper jam
How: Pull the 2 tabs (one left and one right) toward you to open the fuser cover.
(it also flips down to open).
Most of this fix comes from downloading the Users Manual and blowing up page 60 (of 108 pages).
Jan 01, 2011 | Brother DCP-7040 Laser Printer
The printer displays the front door needs to be closed, which it is. With this display the printer will not print. What do I do?
Most likely there is a tab that actuates the cover interlock switch that is broken off.
You can look at the area of the machine that the door closes into and look for openings about 1/4 inch wide and a half inch long. There sould be an interlock switch in that opening. Then look back on the door to the corresponding area and see if you find an area the looks to be broken. That is the most likely problem..
Jan 21, 2010 | Xerox Phaser 8400 Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
After clearing paper jam, display light states back door not closed. It is closed, but I can't print
hai. you try re-start the machine, if your problem not solved, Please check the back door sensor or limitswitch.
May 24, 2009 | HP Office Equipment & Supplies
Display screen says: door/covers open close covers of relay unit??
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
May 21, 2009 | Ricoh Office Equipment & Supplies
Display says "Close feeder 1 Cover"
close the back door of the paper tray 1. the paper tray for this printer actually has a "door" that opens up. silly but true
May 20, 2009 | Dell 3110cn Laser Printer
My Oki B4545 MFP alarm always on
Solution provided by printer manufacturer tech support which worked for me.
1. Open all doors (front & back)
2. Remove tonner
3. Turn off power
4. After 20 secs turn on power
5. Close back door
6. Insert toner
7. Close front door
Fixed now!
Jan 25, 2009 | Oki Electric Industry Oki - B4545 MFP...
How do I reset the Change Drum Soon on the display?
All you should have to do is: -replace the old drum with the new replacement. -with the front door open press the Clear/Back button -press the number 1 button and when ?accepted? appears on the LCD close the front cover. That should do it. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
779 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
