Question about Dewalt DC608K 18 Gauge 2-inch Cordless Brad Nailer
My DeWalt nailer suddenly stopped working. It was working fine. Now when you get ready to nail and compress the nosepiece, it makes the usual noise like it's getting ready to nail, then just shuts off. The orange lights that turn on when you get the nailer ready to go then start blinking.
  • burmee Oct 02, 2009
    Thanks for the help. After I received your tips I actually opened it up and looked inside. The connections were fine, although I noticed the trigger spring starting to become misaligned. The actual culprit in the whole thing was a bad belt. It was shredded and clogging up the winding motor. When the motor senses an obstruction it shuts the whole thing off, which is a good thing. I definetely will be working for those problems in the future however, as I've heard these things malfunction from time to time. Thanks for the help!
    Yes, very helpful. Wasn't the cause of the problem but noticed the symptoms starting to occur. Definetely good to know.
  • 3,741 Answers
If the light keeps flashing ,then the battery is not charged enough to fire the gun. recharge the battery or buy a new one if it continues. ---------------------------- If the battery is new and properly charged and still you have the same problem in the nailer then, open the gun up and you will find that the springs attached to the trigger and the contact tip will not be in a position where they were supposed to be, and thus the contact tips continually pressing the electrical contacts. When you place these in their correct places and reassemble the gun it will start working.but if still the same exact problem then you open it up again and observe what happened when the trigger was pressed if it appears as the motor started and attempted to turn the crankshaft and bring the firing pin back into the cylinder, then its a motor problem in the unit.the motor wiring's are getting short. ---------------- In many cases it has been seen that motor is perfect but the wires of the motor are got cut in between you will find, the drive cable(s) have broken, probably at the attachment ends. Once you energize the motor, the drive belt turns the mechanism inside, and "cocks" the drive pin via these cables. ---------------- this will help.do it carefully.thank you for using fixya.keep updated.please do rate the solution.thanks.
Posted on Oct 02, 2009
My cordless Dewalt finishing gun has stopped firing when you try to fire it in a vertical position. Works fine on skirting and architrave but just gives a little 'pop' if try to fix anything to ceiling.
is this a gas cartridge type of nailer? It could be the effects of gravity on the spray nozzle. try pushing down in normal position but dont fire it. quickly move to ceiling then try firing. I am not a fan of this type of nailer as they are problematic and finicky.
Jan 23, 2015 | Dewalt Tools & Hardware - Others
Will not nail anymore, what could it be ?
Dewalt nailers have some vinyl orings that fail. Usually found within the trigger valve, headvalve, and between the cylinder and cylinder spacer (white plastic piece). Oring kit sold by dewalt will contain most of the orings needed. The kit may not have orings for the trigger. You will at need two orings (2mm x 1.5mm) for the trigger valve stem or just replace the valve. Use white grease or silicone paste lube on all the orings. Good luck.
Aug 26, 2012 | Dewalt D51850 Heavy Duty 20 Degree Full...
Dewalt framing nail gun The hammer stopped re-cioling any ideas?
On pneumatic nailers, this is usually a sign of worn or broken o-rings inside the gun. If the driver isn't retracting it's usually caused by the o-rings on the lower half of the cylinder or the piston ring.
May 21, 2012 | Dewalt Tools & Hardware - Others
My DiWalt 16 guage cordless nailer will not cycle or turn on when I compress the tip to fire a nail. May have bumped the tip while putting it away. Was working fine and then just stopped. Repair shop say...
I would not try and repair this yourself. They are a nightmare to work on and I have been repairing construction tools for 20 years. The reason they want you to authorize up to $200 is because the GRC on this tool through DeWalt is $199. That means that if you take it to, or send it to a DeWalt service center (actual DeWalt, not just and authorized repair shop) they will fix whatever it needs and the price will not exceed $199 no matter how many parts it needs. Here is a link to the parts diagram if you want to see what they are link.
http://servicenet.dewalt.com/Products/Detail/DC616KA
Jul 24, 2011 | Dewalt DC616 16g Cordless 18v Straight...
I have a craftsmans framing nailer when pushed against surface it will not fire and release the nails or even try.
Check the compressor to make sure you have it set at the proper air pressure for this nailer. Typically a framing nailer requires about 90 psi.
Aug 28, 2009 | Air Tools & Compressors
Exterior Galv. 6d cooler 2x .113 21 degree
This nailers are very inclusive , i have experience issues when i try other nails brands, and when i put DeWalt nails they work just fine. keep in mind that most nailers have a safety that when a couple of nails are in the magazine it wont shoot,
Apr 02, 2009 | Dewalt D51844 Framing Nailer
N80 suddenly quit working
There is a nail stuck inthe grove where the nail comes out. There are 4 allen bolts on the front of the nailer.remove them and you can remove the bent nail. Put it back together and your ready to go.
Mar 11, 2009 | Stanley Bostitch N80s Nailer -rebuild...
D51844 Won't Fire Nails
The Dewalt D51844 uses a full round head 20 degree nail. Sometimes the generic brand nails are not made exactly to the stated degree. They do this so their nails will work on a variety of nailers. Best to check the nails angle in relation to the angle of your nailer. Place a strip of nails on the outside of the rail. Align the heads of the nails to a convenient straight edge on the rail then check that the head and shaft of the first nail is aligned with the barrel. If the lower part of the nail projects out further than the head, then the driver will miss the head. If the head of the first nail appears close enough to barrell for the driver to hit it then place a new strip of nails into the mag and slide the pusher foward. Fire one nail, if success, remove the nails from the mag and check if the plastic holding the nails together is projecting in front of the first nail. Sometimes the plastic is not right, too stiff, and will not let the next nail align with the barrell. If the next nail appears ready and slides forward then the driver may not be going all the way up after shot. Check by inserting a metal rod into barrell and push driver up till it stops. If the driver is in the uppermost position, then most likely brand of nails. Use Dewalt nail. Good Luck
Jan 25, 2009 | Dewalt D51844 Framing Nailer
Dewalt DC608K 18 Gauge 2-inch Cordless Brad Nailer Logo
200 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
