Question about Sony VAIO FZ Series VGN-FZ140N/B Notebook
Unable to remove msn messenger 7. i went to change remove and i pressed remove and it came up with-This patch package could not be opened. Verify that the valid windows installer patch package. I want to install msn messenger so i can message, because i can't now.
  • 332 Answers
To completely uninstall MSN messenger, go to RUN and type REGEDIT to bring up the regedit window, now click on the arrow beside HKEY_LOCAL_MACHINE>software and delete it from there, restart your system and try installing it again.
Regards
Posted on Oct 03, 2009
I accidentally uninstalled msn messenger now i want to install msn messenger again
http://download.cnet.com/msn-messenger-wlm-polygamy/3000-2150_4-10559796.html
MSN Messenger (WLM) Polygamy 2009 allow you use multiple copies of msn messenger at the same time. Supports all versions of MSN Messenger including versions 7.x, 8.x, 9.x and 14.x ( Windows Live Messenger). It is easy to use, Double-click MSN_Polygamy.exe to run the program, and then click the Patch button, then your MSN Messenger can run more than one copy simultaneously. Version 14 added support WLM version 9.x,14.0.5027.0908.
http://download.cnet.com/msn-messenger-windows-98/3000-2150_4-10193172.html
http://download.cnet.com/windows-live-messenger/3000-2150_4-10450926.html
hope this helps you
Sep 19, 2011 | Computers & Internet
I have Adobe Reader X installed on my computer and a few days ago it stopped working and I received the following message. This patch package could not be opened. Verify that the patch package exists and...
I have two suggestions for you. You could download the application from adobe and reinstall it and see if that will fix the issue or when you try to remove it either through the uninstall option in the adobe heading in your start menu or from the control panel's add/remove programs section you should be given the option to remove adobe x or repair adobe x. Try the repair option and see if that helps solve the issue.
Good Luck.
Apr 29, 2011 | Dell Computers & Internet
Help microsoft problem. I have a technical difficulty with microsoft. I mistakenly unistalled Microsoft Office 2007... I did asystem restore, when i click on microsoft word it's saying " This patch...
File name: Microsoft Clean uninstaller.exe
File size:351.23 KB
run it and select the microsoft installations that are listed and uninstall them. Once it is finished cleaning up restart your pc and reinstall office. If the reinstall does not work then you have not removed all parts using the microsoft cleaner. Open it back up and check for any left over parts of the installation
If this info is useful please vote for me
Mar 20, 2011 | Microsoft Computers & Internet
Hello I am getting the problem with sign in to MSN messenger, Error 80048820 I have checked / tried all the steps described on...
However, here are some suggestions you should check/try if you haven't already.
1. The date on your computer needs to be set properly -- double click the clock verify that
the time and date are set.
2. If your password information is not saved, verify that you are typing it in with the
correct case (uppercase or lowercase).
3. Change your password @ https://login.passport.com/ChangePW.srf to
something smaller (under 10-12 characters), then try signing in again.
4. If you use a firewall (like ZoneAlarm, Norton Internet Security etc. ), it's possible
that Messenger doesn't have the correct rights to access the Internet, especially since you
upgraded. You may need to re/add Messenger to the allowed list of programs in your firewall
if this is the case.
5. If you disabled your firewall in the past, it still may be blocking Messenger -- try
restarting it and see if that helps the situation. You also might try uninstalling an
installed firewall, to verify that it isn't causing a problem (even if it is disabled).
6. Clear your IE cache and cookies -- open Internet Explorer, click the Tools menu, then
Internet Options, then click the Delete Files button, and when that's complete click the
Delete Cookies button.
7. Check your IE Security settings -- open Internet Explorer, click the Tools menu, then
Internet Options, then Advanced tab, scroll to the Security section, and verify that "Check
for server certificate revocation" is unchecked. Also verify that 'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
8. Click Start, then Run, and enter the following:
regsvr32 softpub.dll
then click OK
and do the same for the following:
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 MSXML3.dll
Nov 04, 2010 | Microsoft Windows Live Messanger
How to remove msn
I take it that you don't wish to use MSN for internet access. You can delete it from your network connections window.
Then you will have to set up a connection that will use either dial-up or some form of high-speed connection. That will become your default connection.
Oct 08, 2009 | Microsoft Windows Vista Home Premium with...
Can not delete acrobat reader 8 from my computer. it tells me: patch package could not be opened. verify that patch package exist and that you can access it, or contact the application vendor to verify...
Do the following to delete it from your Computer: If you are using Windows XP:
Step: Go to Run> Type REGEDIT
Step 2: Click on the arrow by HKEY_LOCAL MACHINE>Software
Search for the Program you wish to delete and Press Delete
Step 3: Restart your system
Regards
Aug 26, 2009 | Computers & Internet
Deleting adobe acrobat
Hi riz1380
If you still have the file that you installed it from run that first. Then use remove software/programs. If you dont have it anymore download it first.
Regards
Go-Tech
Dec 17, 2008 | Dell Computers & Internet
Unable to uninstall Fix-It Utilities 8
Use REVO uninstaller. It is free and good uninstall utility
Dec 13, 2008 | Avanquest Fix-It Utilities 8 Professional:...
MSN Live is not Responding, I sign in to MSN Messenger Live and it doesn't respond. What can I do to fix this problem with MSN Messenger Live?
HEY guys!!
i had da same problem i went to google and i didnt find any way so i start finding it my way ..IF msn is not responding after 3 seconds when you signin...And if you did system restore dat what had happened to me ... i ve the answer... Go to Control panel> firewall>exception> .... IF YOU VE MORE DAN TWO WINDOWS LIVE MESSENGER CHECKED..here is da mistake ...just uncheck one and signin and see..IF its again not workin check the other one.. CAUTION: leave da msn (phone) NO NEED ........I HOPE MY ANSWER IS HELP FULL
Nov 10, 2008 | Microsoft Windows Live Messanger
When trying to open adobe reader 8.1.1 get following message: patch package could not be opened. verify that the patch package exists and that you can access it, or contact the application vendor to verify...
it sounds like the application that is needed to uninstall the version 8 is corrupted or missing. Try reinstalling version 8 first then uninstall it before loading version 9. If you can reinstall version 8 and it asks you if you want to repair or install, choose install to get all of the files back before uninstalling it again. Always uninstall from add/remove programs. If deleting it from program files instead of uninstalling it correctly it will cause problems.
Oct 22, 2008 | Computers & Internet
Sony VAIO FZ Series VGN-FZ140N/B Notebook Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
