Question about Port Incorporated 8-port 100Base-TX Mini Hub(External power adapter) (195009001)
Lost Power Adapter for Unicom Mini-switch/8 8 port
Lost Power Adapter for Unicom Mini-switch/8 (8 port 10/1000base-tx switch). There are no specs on the case to let me know what it needs.Only says DC IN.
    Scholar:
  • 50 Answers
Method 1: buy a power adapter that has a switch controlled output voltage - they usually have 3V - 4.5V - 6V - 7.5V - 9V and 12V selectable output. Start with 6V and if its not working unplug, select 9 and try again etc. etc.
method 2: open the case and locate an electrolytic capacitor right near the power plug - the biggest one. Note the voltage (for example it may say: 1000uF/15V) and have in mind that your device MUST work at a LOWER level that this.
you can combine the two methods to be safe...
Posted on Oct 10, 2009
I have lost the power connector and usb connector for a DR-1 where can I purchase them?
From the looks of the port on the side in the manual, all you need is a USB to Mini USB cable, you can also get a Mini USB AC adapter separately or as part of a combo with the cable. Hope that helps. Here's a picture of a Mini USB tip to ensure that it looks correct.
Feb 28, 2011 | Tascam DR-1 MP3 Player
Cnet CSH-800 8-Port Ethernet Switch no power
Check the power adapter with a multi-meter. The voltage on the plug that connects into the Ethernet switch, the voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the adapter is faulty and needs to be replaced.
If the voltage of the adapter is OK then the Ethernet switch is faulty and you need to buy a new one.
Dec 11, 2009 | Cnet CSH-800 8-Port Ethernet Switch
IOGear (GCS632U) 2-port KVM Switch problem. All functions well it seems after connecting for first time Mac Mini and XP Windows Dell PC except when switching to Mac I get a blank dark screen. Another side...
The IOGEAR GCS632U is designed to work with VGA computers and monitors. Using the Mini DVI to VGA adapter is not guaranteed to work with this KVM switch.
The Mini DVI to VGA adapter can only convert the port, but it does not have an ability to convert the signal from digital to analog when it's connected to the KVM switch.
What you need to have is a DVI to VGA SIGNAL converter. Unfortunately, I don't have a model number handy, so I would suggest to contact IOGEAR, because I'm sure that they already have a work around with this issue.
Thank you and good luck!
Oct 11, 2009 | IOGear GCS632U 2-port KVM Switch
Need power supply for Hp 336044-B21 KVM Switch. (DVE Switching Power Supply, Model DSO-142L) in the last two month I lost three same switches with the same problem - power supplies...
There are a few things that you can do. First; try to go online to HewlettPackard.com and locate the power supply. Second;go online to ebay and search for the power supply. Last;locate a Batteries R Us store in your city. They have a huge supply of batteries and power adapters. If you do not find a HP adapter the store person can help you find one that is complimentary to your HP adapter.
May 29, 2009 | HP 336044-B21 8-port KVM Switch
Reset speed from 10Mbps on 100Mbps (D-Link DE-1824i)
Tony,  I was looking at the specs and found these lines :- Choices of 12 and 24 10BASE-T ports per hub
1 100BASE-TX port (for connection to 100BASE-TX hubs) Which is saying that the user/pc ports are fixed 10Mps and there is one 100Mbps uplink port to connect two hubs together.
http://www.dlink-intl.com/Products/Hubs/DE1824.htm
Apr 13, 2009 | D-Link DE 1824i (DE-1824I) Networking Hub
A lot of port of panel unicom of 48 ports not networking.
Sorry but there is no software available for this panel, You have to change the panel or plz check whether only faulty modules replacement is possible?
Thanks for contacting Fixya.
Mar 23, 2009 | Unicom Patch panel
Adapter specs
hi..
i've also got one without DC adapter... and looking around. find this link here: http://www.corg.ru/products/Network%20equipment/Compex/TP1008C saying: Power Supply: External power adaptor input 220V-110V, output 7.5v/1A
hope it helps
Aug 07, 2008 | Compex MicroHub 8 Networking Hub
Computers & Internet Logo
198 people viewed this question
Top Port Incorporated Computers & Internet Experts
David Payne
David Payne
Are you a Port Incorporated Computer and Internet Expert? Answer questions, earn points and help others
