Question about Autopage Vehicle Parts & Accessories
Car will not start using the key fob all fuses are good, lock/unlock buttons work. i have had this remote starter in this car for nearly 3years
  • 509 Answers
In some cases, if you hold down a button too long on the remote fob, the starter module goes into a setup "menu", which is possible. You didn't change the fob batteries lately, did you? It sounds like you will have to 'retrain' the fob with the starter unit so that it re-learns what to do when you push the start button. With the "Ultra" brand, you use the button on the windshield antenna to retrain your unit. I'm not sure about the Autopage brand. An installer should be able to reprogram it for you for $10, and that would be the easiest if you can't find the data by doing a Google search.
Posted on Oct 10, 2009
Viper remote starter won't start the car even with a New key fob battery, it will crank for about one second then nothing.The car starts with the key and the door and trunk locks work with remote fob
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
owner's/service/repair/parts/maintenance manuals etc everything
this website www.reliable-store.com
it's a very good website for vehicle problems even as old as 1991 ford..
Feb 26, 2018 | Cars & Trucks
Why don't power locks work?
it maybe the BCM may have a problem or needs to be reset.
Sep 06, 2015 | 2010 Chevrolet Chevrolet Malibu LT
Doors lock...key and FOB will not unlock
missing chip? empty battery in FOB? lost coding? blown fuse for remote starter circuit?
Jan 06, 2014 | Isuzu Ascender Cars & Trucks
Both key fobs for honda pilot 2006 no longer works. Do I need new keys or is it something internal such as a fuse?
First thing, does the red light on the remote light up when you push any of the button
if no, then replace battery inside remote
if yes, then try repograming the remote to the car again.
-Have both remote ready. fob#1 and fob#2 (doesn't matter which one is #1 or #2)
-each step has to be done within 5 sec or it will not work, but don't do it super fast.
1.turn key just to the "on" position (not starting) and push "lock button " on fob#1 once and release
2.turn key off
3.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
4.turn key off
5.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 7)and push the "lock button" on fob#2 twice.
8.turn key off and remove key from ignition.
if you did it right, remotes should work again.
good luck
Dec 17, 2010 | Honda Pilot Cars & Trucks
2007 gmc yukon denali wont unlock w/ keyfob
Check the buttons.. I have an 06 Grand Prix with the Remote starter on the top and it seems that the conductor on the buttons worn out.. Take the keyfob apart, pull the rubber buttons off the chip, lick your finger and touch the place where the unlock (right side of the fob) would be. That should unlock your doors. I just did it with mine. I would just buy another fob on ebay and change the buttons out.. Hope this works
Apr 23, 2010 | 2007 GMC Yukon Denali
Hello I have a Orbit remote starter (model Hybrid) that was installed on my truck (automatic transmission) 2 years ago. As of yesterday, it won't start my car as it has always done (from the same...
the starter is in valet mode. your led on your attenna is probably on all the time right??? turn the key on and off 5 times or check your manual to see how to get the starter off of valet mode. read your manual
Jan 14, 2010 | Ford Sport Trac Cars & Trucks
But a used 2006 solara but key fob does not remotely open trunk. Any suggestions?
Yes, insure that you have power to the trunk lock inside trunk, If not could be lose/broken wire or shot fuse. I am sure the key fob does work for the doors? If not have key fob battery replaced. Also, a quick check on power to trunk lock, check to see if have remote power button inside car, if it works power is good. Defective key fob would then be indicated.
Sep 18, 2009 | 2006 Toyota Solara
Dealer install remote starter bypasses kill switch
1) remote starter was not hooked up to the factory arm wire
2) trunk release was programmed to disarm factory alarm before popping trunk
3)parking light wire on remote starter was not hooked up
4)disarm wire from remote starter was not hooded up
5)this is not normal and they should fix the problem or have it done by some one else and have them pay for it, how much did they charge,
Bring it over I'll fix it right and not charge overpriced amount
Jan 11, 2009 | 2005 Hyundai Sonata
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
Dec 10, 2008 | 2003 Audi A6
Key fob not working
hello mate.. if it has stopped working you might want to check the battery first.. if you are sure that the battery is fine then consider reprogramming the fob to your car.. here are the steps to follow.. NISSAN
Remote Control Fob Procedures:
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and emergency hazard reminders.
When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed:
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure:
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key's.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key's for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds.
http://www.autokeysquad.com/nissan-fob-programming
i hope this can help you.. :)
Jul 28, 2008 | 2005 Nissan Sentra
Vehicle Parts & Accessories Logo
1,007 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
Charles Osborn
handt729
Level 1 Expert
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
