Question about Sony Cyber-shot DSC-W70 Digital Camera
Blury picture when using flash - Sony Cyber-shot DSC-W70 Digital Camera
My pictures are blury and I am tired of it.
First make sure you're on Auto mode (press SCENE and choose AUTO mode)
Use permanent flash by pressing UP until the flash logo gets selected, then press OK.
Also, if you don't want to use the flash, put the flash on AUTO and press menu, go to "Set up", scroll to "Anti-shake AE" and set it to "Auto", press OK to save settings and try taking pictures again.
Nov 09, 2010 | Nikon COOLPIX L20 Digital Camera
Bad indoor pictures. When I take indoor pictures and it says to use the flash I do but then my pictures turn out dark/grey. Then I try it without the flash and they are brighter but then blury. I even...
The flash has a range of up to around 10 feet at the wide end of the zoom, down to 6.5 feet at the tele end. Maybe you are using it on to big a distance or at to low ISO? Try setting the ISO to 800 and see if it helps. images get a bit more grainy at 800 ISO but are also less prone to camera shake, if you use it without the flash. The camera goes as high as 1600 ISO, but images get very grainy at that setting.
Jul 01, 2010 | Canon PowerShot SX100 IS Digital Camera
Pictures taken inside are coming out dark and blury
Please readjust the ISO: Different SCN (If you're experiencing this problem with your low light pictures try and use SCN night, the logo shows a moon and a star, with or without Flash.
Jan 01, 2010 | Kodak EasyShare C875 Digital Camera
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
NIght time Evening Pictures
check the mode and check the flash to make sure it is on auto
Dec 12, 2008 | Olympus FE-230 Digital Camera
Blury and flash problems
Hello Chad,
As you told the condition of the are blurry,This problem is not related to the setting or master reset.This cause is due to malfunctioning of zoom optical motor and sensor who focus the object.Therefore, the solution of it is, You have to change its optical lens assembly.
I often deal these sort of cases in routine in said Model Although it's a very fine camera but dusty and moisturized conditions cause this problem.
Thanks & don't forget to rate.
Apr 12, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Blur image
I am having a problem with blury pictures. Every one I take is blury and it also seems the flash wont go off. Now the pictures are blury even in the daytime. Anyone that can help me please do!!!!
Mar 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Blury pictures
change the resolution setting in setting. and also you can adjust diplay bright ness and contrast for bets view & pics .thsi will solve the problem. Thanks Sangita
Jul 08, 2007 | Samsung Digimax S500 Digital Camera
The subject is very blury or out of the picture
You are expecting too much for any auto mode. When shooting under low light conditions, the camera may take longer to achieve focus lock. If the subject is moving too, it will take even longer to lock focus. Try using manual focus for the conditions you described.
Sep 06, 2005 | Olympus Camedia C-765 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
