Question about Optical Coating Model 108 VHS VCR
Sansui dvd player wont play and dvd's... shows up as incorrect disc c104 error
I have a sansui dvd/ vcr combination player, it worked fine at first but now reads the disk and shows "incorrect disc c104 error".  What is this and what can I do to fix this problem?
The fact that a certain format did work once indicates it most likely is the infamous "reset" problem we are experiencing with our Sansui--the same model that you have. This appears to be memory"reset" issue since firmware instructions work fine with formats allowed, per instruction manual. Especially, if your dvd player fails to read upon disk insertion. There were some appended instructions with my unit--stating a 45 second delay required for reading the disc if I recall correctly--something to that effect. However, this will not usually correct the power "reset" issue. It has been suggested elsewhere to unplug the dvd player for 30 minutes, then try again. This momentarily corrects at least some of the problem. I would think that 5 or 10 minutes unplugged would be plenty of time for bleeding off corrupted (or overloaded?) memory issues. It's interesting that our other unit--the same model purchased at the same time--never had this problem. Still looking for answers myself... Good luck!
Posted on Jul 09, 2012
  • 579 Answers
Try cleaning the optics with one of those DVD cleaners.
When that probably doesn't work, you can hand clean the optics if you can figure out how to get at them. (easy on some, hard on others) If that doesn't work, it is prbably not worth going any farther
Posted on Dec 28, 2007
I have a Sansui model VRDVD4005. When I put a DVD
I think you need to take it to the service center, because there's nothing that you can do all by your self.The problems starts from the optical lens/ laser pick up, replacing the lens could be necessary.
Mar 07, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
you will need to run a cleaning disk in it , if that won't work then it will have to be taken apart to clean the laser eye manually
which then if you can't do this then you will need to take it to a local repair shop where they can do it
Oct 26, 2008 | Sansui VRDVD4005 DVD Player/VCR
Cannot format a dvd-rw disc or record to the disc.
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Dec 30, 2009 | Sansui VRDVD4000 DVD Player/VCR
When I insert a disc (one that I have used with this machine in the past) after "reading" it states "incorrect disc C104". The vcr part still works ok.
You could have just a dirty lens that will require you to remove the cover of the player, clean the glass laser eye lens with rubbing alcohol and a cotton swab. This usually always work, unless of course the laser circuit is faulty, then it will need to be replaced.
Dec 17, 2009 | Sansui VRDVD4005 DVD Player/VCR
Receiving error "incorrect disk c104" The DVD is brand new and other older DVDS work fine
My best advice here is ether the disk was not written for your region or it was nto written correctly if its a burned disk or it is dirty with scuffs or scratches ether way if other disk is running great then this is pointing at the disk your working with here, Simply try this in another player to see what is ruled out here.
Could be a bad sign of a laser solder bubbles not formed right if you know what I am talking about you will know what I mean.
Nov 17, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
DVD-RW will not record. Using Memorex DVD-RW and get the "Incorrect disc C104" message. Where can I get the correct disc and what are they? these used to work, but the new ones don't.
I have the same machine and I've used Memorex DVD-RW 2X/4.7gb/120min dvd's for a long time. The newer ones at Officemax are 4x, 8x, 16x and 52x they won't work. I think they have to be 2x only!!!
Nov 06, 2009 | Sansui VRDVD4005 DVD Player/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
DVD recording or playing.
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
Feb 07, 2007 | Sansui VRDVD4005 DVD Player/VCR
Televison & Video Logo
312 people viewed this question
Top Optical Coating Televison & Video Experts
Are you an Optical Coating Televison and Video Expert? Answer questions, earn points and help others
