Question about Garden
I HAVE A ELECTROLUX WEED EATER MODEL TRIM AND EDGE RTE 115
I HAVE A WEED EATER MODEL TRIM AND EDGE RTE 115 AND NEED TO PUT NEW LINE ON SPOOL
3 Suggested Answers
  • 201 Answers
SOURCE: I can't seem to find the replacement spools of
lowes supply carrys a good variable supply of replacement lines different thicknesses etc....hope this helps..chris
Posted on May 13, 2009
radar001
  • 1051 Answers
SOURCE: How to respool an electric Weed Eater Trim and Edge RTE 115
The nylon string is simply spun onto the emty spool. There should be an arrow on the top of the spool indicating the direction to wind the line. If the spool is missing a notch to hold the line to get started, use your finger to hold it in place for a few full wraps.
Posted on Apr 03, 2010
I Have a Weed Eater Model W25CFK I need to put new string on it ...It doesn't have a spool you use two individual pieces of line and I can't remember how to do it and can't fi
There are a couple of different heads that doesn't have a spool on 1 you pull the left over pieces of old string out from under the and the push the new short pieces into the front of the head, another you line up two arrows and then put a long piece of string throw the head eqail on both sides and then wind the head to pull the string in, another you take off and feed the line down inside.
Oct 13, 2014 | Garden
I like to know how to wier the line om my poulantrimmer model ppo25\
Hi rlgingas...
1 Press the lock and rotate the spool counter-clockwise
Some you will have to remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Apr 03, 2010 | Garden
Trying to replace the line in weedeater Twist/Edgs RTE 115c. I can not get the line to feed into the spool. How is this done?
search youtube "change line on a weed eater" there are several videos there maybe one is similer to yours
Oct 25, 2009 | Electric Garden
Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
Jun 13, 2009 | Poulan Garden
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
I can't seem to find the replacement spools of line for my Weed Eater Model number RTE 115 C. Do you have any suggestions?
May 13, 2009 | Garden
Need motor brush
Try a power tool repair shop
Try an electric motor repair shop
Try to find brushes that have the same length spring, same size spring. If they are a little big, they can be made smaller by dragging them on a flat file 'till they fit nicely.
Apr 28, 2009 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
