Question about HP J4680 Office Jet All-In-One Printer
How do I send a fax? - HP J4680 Office Jet All-In-One Printer
    Scholar:
  • 53 Answers
perform the steps provided in the below webpage to send fax:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01882481&cc=us&lc=en&dlc=en&product=3692888
Posted on Oct 03, 2009
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Fax machine will not send. Dial # Push Send and
If the fax is not set for tone dailing and it is set for pulse dialing the fax will not register the # button.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Dec 08, 2008 | Office Equipment & Supplies
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP J4680 Office Jet All-In-One Printer Logo
74 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
