Waste ink tank can it be cleaned - Office Equipment & Supplies
  • 10,865 Answers
Http://www.ehow.com/how_4492150_ink-tank-canon-photo-printer.html
all of these tanks clean about the same way. this link will give you the info you need.
Posted on Oct 02, 2009
What are printer error messages 4F and 48 on Bother MFC-J430W wireless printer
Error 4F and Error 48.
Actual Message will be:
Unable To Init 4F
Unable To Clean 48
These messages indicate the Waste Ink Tank is full.
This is the space in your machine that will store all the ink that is used in cleaning the printhead. Once this is full the only way to continue printing is reset the Purge Counter and clean out the Waste Ink Station. If you do the reset and not he cleaning of the waste ink station you will eventually end up with the waste ink tank overflowing and leaving a huge mess to clean up. If you clean out the tank but not reset the purge counter it won't work till then.
Unless you are satisfied with your ability to dismantle and reassemble your printer you may want to just replace it as it can take some time and causes alot of mess.
May 01, 2016 | Brother MFC-J430w Inkjet All-in-One
How to clean waste tank on MP730 "waste ink tank
  1. press menu - copy - #
  2. Select TEST MODE.
  3. Select [8] PRINTER TEST in TEST MODE.
  4. Select 3. [EEPROM CLEAR].
  5. select 0. [INK COUNT].
  6. press the [OK] key
  7. press stop to cancell
  8. restart the printer
Oct 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
How to clean waste tank?
The waste ink tank is on the Drum, you have to disassemble the drum to clean and remove the wasted/old ink. Please follow the instruction provided here.. FixYa's Tips on how to remove the waste ink from the waste ink tank (laser printer)
I hope you can follow the simple instructions.
Good luck.
Thanks for using FixYa.
Jun 27, 2010 | Samsung CLP 300 Laser Printer
IP 6700 d waste absorber nearly full. How do I resolve?
Hi. I think the problem on that one is the waste ink tank is already full, so you need to clean it or replace the pads on it, because when you are printing or opening your printer it blows little amount of ink to the heads so that it will not be clogged, and that ink goes into the used/waste ink tank. Also after cleaning the used/waste ink tank you need to reset the counter of the printer so that it would print again, you can just download the counter reset software2_bing.gif over the internet or just bring that machine to an authorize canon printer technician. Hope this Helps
Jun 09, 2010 | Canon PIXMA iP6700D InkJet Photo Printer
Sir , my printer canon pixma ip 1200 when i start to print it show waste ink obsorber is full. please help
Jun 09, 2010 | Canon PIXMA iP1200 Photo Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Waste tank is full, How do fix it, can I clean it myself?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Ink waste Absorber
you are correct about the waste ink tank,did you check the pipe (if any)which use to carry the ink to waste tank,if it is clogged than also the problem will arise.
Mar 31, 2008 | Canon PIXMA iP2000 InkJet Printer
399 people viewed this question
jasbo
jasbo
