Dishwashers
Problem for Bosch Dishwashers
Generic problem for all Bosch Dishwashers
Wash cycle OK, but the
By pqholloway on Oct 02, 2009
Wash cycle OK, but the drying cycle is faulty. The dishes are wet after 12 hours. Will not dry contents of washer! #SHU680SUC/U06
Solution #1
posted on Oct 12, 2009
Not Rated)
hoymate1952
Rank: Master
Rating: 90%, 10 votes
Make sure your water is hot enough. Water temp has to be at least 120 degrees even to activate the soap and also heats your dishes up enough to allow them to dry. Also, be sure you are using rinse agent such as Crystal Clear or Jet Dry. These break the surface tension of the water and allow most of the water to flow off the dishes and down the drain.
Hope this helps! Ken
Was this helpful?
Yes
No
Solution #2
posted on Oct 10, 2009
Not Rated)
rossclifton
Rank: Wiz
Rating: 84%, 44 votes
your heating coil has gone bad it`s that rod looking thing in the bottom of your unit under your spray washing spinner depending on the age of your unit your probley better off buying a new dishwasher
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
My Kenmore model# 665.15817990 dishwasher has not worked as more than a dryer rack for the better... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
