Question about Acer 19" LCD Monitor
Turns off and on by itself
Its as if it has a life of its own.
Symptoms are:
1) The monitor seems to want to turn itself off after 1 second of being turned back on.
2) i turn it on, it turns itself off
3) Sometimes when i just let it do its thing, it turns itself back on, for more than 1 second (ranging from 2 seconds to 10 minutes).
4) user (i) have no control of the monitor
5) After it turns itself off, i can press the menu or the auto button on the monitor, and it'll turn on, but it turns itself back off at will.
i've checked my pc for viruses and any other baddies. No issues.
i've checked all the connections - no issues
Help!! i got the monitor about a year or so ago.
  • 1 more comment
  • Noppo Dec 21, 2007
    Thank you. i'm all over it. i'm able to see now. but it's so intermittent, it's very reliable. i appreciate your feedback VERY Much. Can't thank you enough. It's not been a problem for 1.5 yrs. Just all of a sudden. Gonna get off now while i can still see.... Apologies. i'll get back on once i fix it based on the above. Very least i'll be able to find out if the above helped.
    m(_ _)m
  • Anonymous Mar 05, 2008
    i have a same problem my DEL Monitor also. pls give me a solution for me.
  • oliveiraleb Sep 20, 2008
    nº1 my monitor acer al1911 does turn on, no signal, no lights, nothing.it looks like dead.can you help me with this?
    nº2 my monitor acer al1711 turn on black after a few minutes working, with green led still on,came back again after press power on again but after a few seconds turn black again.can you help me with this also?
    thanks
    Problem Solver:
  • 7 Answers
When the monitor does work, are you able to see image very well? If so, then check the monitors conection to the PC. Look into the plug itself, are any of the pins bent?
If a computer monitor does not see a connection, or is not getting video feed, it will shut itself off to save power.
Could also be as simple as a bad cord on the monitor as well.
If not, then it could be the computer resolution set too high. To fix that, reboot in safe mode (hit F8 during boot) and change screen rez while in that mode.
Posted on Dec 21, 2007
    Sergeant:
    Champion:
  • 209 Answers
Ok so its connected to your pc?
check settings on the monitor itself [if you'restill able to do that]
disconnect all your usb devices restart your computer and try again.
Is it in a cold room ? that might be the problem.
Is it in the same powerbar as your computer ?
I'm not sure but if your power outlet where you connect it is simply looped to the rest that are in use [lazy electrician] then it might turn off because a power shortage.
Good luck
The problem is caused by bounce in power buton.
For the repair replace by a new one.
Posted on Sep 15, 2008
Tv power cuts on power light lit no picture then Tv turns it self off, when picture appears there's waves in picture and tv turns itself back off and on with no picture just black scree
Hi Patty
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 14, 2015 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
My 37 inch Sylvania TV model LC37SS9 M turned off by itself and to turn back on. I was watching dish network at the time
- Flickering screen
- Dim screen
- Slow start
May 01, 2015 | Sylvania Televison & Video
Why my tv turns itself off
- Flickering screen
- Dim screen
- Slow start
Feb 27, 2015 | Panasonic TC-P50S30 50" LCD HDTV - 1080p,...
Random shutdown
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Balance CM2015 15" LCD Monitor
RCA flat screen TV turns off by itself and won't turn back on
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | RCA L22HD41 22 LCD TV
Tmy monitor shows the images only for 20 seconds, then it turns black.
Hi hope your monitor issue has resolved. I would suspect the problem is a hardware issue then a software setting. Since the monitor is over three and half years old, if your monitor is a LCD with CCFL back light and had been used almost every day, there may be 3 possible hardware issues. First is the internal power supply, that can go wrong due to heating problem within the monitor, this problem usually cause the monitor to display poor quality picture and may show interference lines on screen prior failure. Secondly, it may be the inverter that drives the back light, which may fail due to the safety circuit kicks in, because it involves with high voltages. Thirdly it may be the backlight itself, which is like most compact CCFL energy saving lamps that flickers or turn itself off when it reaches the end of its service life. This problem usually caused the monitor to show redness or yellowness images prior failure.
All of these can be resolved by qualified electronic repairers, all the best.
Nov 10, 2011 | Computers & Internet
My Samsung SyncMaster 740N occasionally turns itself off. Timing varies and the condition varies. Usually the screen just goes black - from seconds to hours after it is turned on - the blue LED remains...
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
Mar 15, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor goes black for a few seconds
Try swapping the monitor cable from the working monitor to the other video connection on your computer. Effectively reversing the connections to isolate whether your problem is the video card in your computer or the monitor itself. If you find the working monitor displaying similar symptoms, then check your video drivers and ensure that you have all power saving features, screen savers, etc... turned off.
Apr 06, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Acer 19" LCD Monitor Logo
379 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
