Question about Creative Labs Zen Digital Media Player
Zen x-fi won't turn on
Creative labs " Zen x-fi " mp3 player won't turn on. Sometimes it's fine and sometimes it justwill not turn on. Reseting doesn't seem to help. But later it'll turn on ok.
It's charged up before I turned it off, and when it finally turns on , it has a full charge. If I connect to my computer it comes on.
SOURCE: Creative Zen Stone Plus won't sometimes turn on
try sync-ing ur mp3 with windows media player 11.
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?
then click on "Click Here if you require further information/assistance."
Posted on Nov 19, 2008
SOURCE: creative zen
Here's the deal just reset it then put on the charger
Posted on Jan 13, 2009
Benimur
  • 6966 Answers
SOURCE: Creative Nomad Jukebox zen xtra says Firmware problem
Hi and welcome to FixYa,
It would appear that the fix requires a Windows machine. Solution then would be two fold:
  • download the firmware update/fix even meant for Windows;
  • install and run Windows inside your Mac.
The last could be achieved by:
Of course the easiest is to use a Windows based computer of a friend.
Your Creative Zen Nomad Xtra mp3 player uses a memory system similar to a flash/thumb drive much like the hard disk of any computer. Just as a computer on certain instances freezes/hangs, the same would happen to your MP3. Like again the computer, the OS would need to be re-installed. In your MP3 the OS is the firmware which has to be reloaded/updated.
Good luck and thank you for using FixYa.
Posted on Feb 14, 2009
SOURCE: Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Posted on Mar 26, 2009
SOURCE: firmware update went wrong
What operating system are you using? The Zen Touch firmware update will fail in Vista or 7 -- you need to run the update from an XP install. Once you successfully get the 2.11 firmware on the Touch, it will then interface with those later OS's without difficulty. Also, what version of Windows Media Player are you running? Believe it or not, this makes a BIG difference. The latest Media Player 11 will cause the firmware flash to fail, as will WMP <= 9. I have three separate players that have experienced this problem, including one that had been disassembled THREE YEARS AGO after a failed flash, and was able to resurrect all utilizing this method:
(1) Uninstall everything Creative: the driver, Jukebox, etc. Delete the Creative folder from Program Files. (Some amendment to these instructions may be in order if you have a Creative sound card -- I have built-in Realtek sound so it didn't apply in my case). A restart may or may not be required: go ahead and do so to be safe.
(2) Plug the device in after restart. Windows will want to find drivers for it -- cancel that process. Open the Device Manager. The Touch should come up with an exclamation point next to it (since the drivers were not uninstalled): right-click and select "Uninstall." I have seen instructions on the Web to also uninstall all USB root hubs, but I have found that unnecessary and a pain if you have a USB keyboard and/or mouse. Unplug the device. Restart.
(2) If you are running a version of Windows Media Player not equal to 10, either install 10 (if you have 9 or below) or roll back from 11 if you have that. Restart.
(3) Plug the device back in. My supposition is that this is particular to WMP 10, hence the problems with other versions. The device should pop up as "Creative Zen Touch:" if Windows asks to find drivers, cancel that process, and the device should now come up as an "MTP device."
(4) Since the firmware flash failed, the Zen is probably in recovery mode. Launch the firmware updater software on the computer, and stay at the language selection screen. Choose option 3, "reload firmware," from the recovery menu. It will inform you that it is "deleting old firmware" and then will give you a short period of time with a dialog saying "start firmware update" on the Zen screen. During this time period (about 2 secs), press the language selection of your choice on the computer in order to start the update. It should go through successfully this time.
Posted on Jun 10, 2009
My creative zen mp3 wont load
try conecting it to the computer and reinstalling the firmware to it that helps sometimes
Jul 10, 2010 | Creative Labs Zen Micro MP3 Player
Creative zen mp3 player won't turn on. already tried resetting
Mine did exactly the same and i thought it was dead, but when u are reseting it keep it plugged into the computer while reseting it and it should turn on. It worked for mines anyway.
Jul 15, 2009 | Creative Labs Creative Technology Zen MP3...
Frozen 6gb Zen Neon " Can reset via side pin but only
I have tried reseting the Zen Neon numerouse times, but it keeps displaying the creative sign.
Aug 30, 2008 | Creative Labs Zen Neeon MP3 Player
Argh! Problem with my Creative Labs ZEN TOUCH 20GB MP3 Player
this is a common problem try this:
smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I
Nov 11, 2007 | Creative Labs Zen Touch MP3 Player
Zen v plus
sounds like bad hard drive try using the recovery tools at creative:
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?region=1
Sep 01, 2007 | Creative Labs Zen Micro MP3 Player
Creative Zen Micro sound
maybe the problem is on yhe jack... you can can check the jack by dissamble your zen... this is the good link how you can dissamble your zen.. http://www.hardwarezone.com/articles/view.php?id=1331&cid=9&pg=1
Mar 13, 2007 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen Digital Media Player Logo
534 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
