The top half of my 6X4 landscape print is not print the photo. Only the lower half reflects the photo.
SOURCE: Printing 1/2 page
Ok, this is what I found when I finally broke down and decided to take it apart. There is a bar with two cams on either side of it that are used to engage the print head to the paper. The smaller cam on the bar has cracked and no longer pushes the print head down on that side of the paper, causing the half picture. What I did was remove the cam from the bar, glue it back together, then wrapped it tight with thread (only one layer, there is a clearance issue), and put epoxy around the thread(to help reinforce the cam). Once the epoxy had cured, I reinstalled the cam to the bar. The cam did crack again, but the thread and epoxy held it tight to the bar. After reinstalling the bar and putting the rest of the printer back together, I crossed my fingers and tried to print a picture. Tada!! It worked!! I have since printed a few more and have not had a problem yet. It may only be a temporary fix, and nothing could be better then the original replacement part (if you know where to get it), but this has worked for me. Good luck and be patient.
SOURCE: Only half of picture is printing
I have the same problem where only the bottom half of my photo prints. It worked fine for a long time. I even tried flashing the printer up to the 2.11 firmware version from 1.90 - still nothing. Changed paper and cartridge. NOTHING. Tried attaching it to both my PC & MAC and even print stand alone picture from camera and a SD memory card on the side. NOTHING.
I think the problem is with Kodak... My trouble started when I decided to move my Dock Printer from PC over to MAC. The new drivers have you flash the Firmware. To do this, you first must hold down the Print and Red EYe Button (The button directly to the right of the big print button) with the power cord unplugged and then plug it in holding the buttons in for 2 seconds afterward.
This put the printer into Edit mode and allows the firmware to upgrade the printer. Once I did that, THAT'S when my problem started. I think these crappy printers can NOT self calibrate and they must be factory set. Most likely, they need to do it at the factory themselves and are all to happy to charge you to ship it off and do it for you.
THANKS KODAK!
What a POS.
SOURCE: Easy Share printer Dock series 3
The problem is most likely a broken plastic lever on the end of the
shaft that moves the print head. The plastic lever is keyed to the
shaft by a flat on the shaft. The plastic has a tendency to split at
the edge of the flat, resulting in the lever slipping on the shaft.
This in turn results in one side of the print head not contacting the
paper with sufficient pressure. The other end of the shaft has a thick
plastic sector gear which is much less likely to break.
I fixed
mine by making a clamp from a metal spacer (made from split tube about
1/8 inch long) and force fitting it over the part of the plastic lever
that fits on the metal shaft (on the end towards the inside of the
unit). There is just enough clearance to do this without hitting the
print head frame.
To remove the plastic lever, first remove two
screws from back of unit, then pull up on top of unit, unplug two
ribbon cables from circuit board
and remove top. Then unplug two remaining ribbon cables from circuit
board, and three screws holding circuit board. Lift circuit board and
fan/fan-holder as one piece. Finally, disengage tab on plastic retainer
on end of metal shaft, rotate tab straight up and lift shaft up and to
the side (may require a little wiggling). The plastic lever slides off
the metal shaft.
SOURCE: Only top half of the photo is printed on Easyshare
This usually represents a communication issue...
It could be between the doc and the printer (try a new USB cable) or it could be in the printer dock itself - if so, you would want to call Kodak to get a repair if they still repair them or maybe they have an upgrade path.
SOURCE: We have a Kodak easyshare series 3 camera and dock
SOLVED!!
eppelr is correct, the small white cam on the right hand side at the top (internally) cracks and this allows it to come loose on its shaft and stops it from pressing the thermal head down onto the ink film on one side. If like me you have the top of the range bluetooth model its worth buying an old basic model off ebay for a tenner and robbing the shaft out of that. The mechanics are more or less the same and the shaft itself is identical, Doubt you would be able to buy the shaft seperate from Kodak, Thanks eppelr, I now have two working plus 3's.
If anyone wants pics etc please get in touch
