Question about Lite On LTC-48161H CD-RW/DVD-ROM Burner
I was attempting to install program and now, the drawer will not open. I did the paperclip trick to no avail. It makes an attempt to open but the rod (?) seems to not be able to push the drawer open. Please give recommendations.
  • Lite On Master
  • 3,289 Answers
The "paperclip trick" should work - try doing it with the power to the PC off next time. You may have to angle the clip a little left, right up or down to find the point that needs to be pushed. Each time you pull out and push in the tray will move outward. - repeat as needed to remove the disk from the tray.
Power up the computer and gently push the tray in manually. It make not eject w/ the button or software command until the next power down / power up cycle, and then it should return to working as expected.
Posted on Oct 02, 2009
  • Steve Oct 02, 2009
    You might need a paper clip that is a little bigger so that the end can go in deep enough to press the release mechanism.
Disk drawer will not open
Did you tried with a crowbar? It's a joke.
You can use a paperclip. Normally you have a litlle hole below the drawer, when you unfold your paperclip, you can then insert them in the hole and open your drawer.
Aug 07, 2012 | Computers & Internet
Need to replace front of storage drawer
Instead of replacing the door of the storage drawer, can you please use some chemicals which will remove the bad stains. Make sure you use chemicals which will not affect the steel. Lots of chemicals available in the market to remove bad stains for steel.
Thanks.
Mar 31, 2012 | Refrigerators
My jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Mar 27, 2012 | JVC Audio Players & Recorders
I installed the camera using the cd and when tyring to use it on messenger, it says that no webcam was found. How can I get it to work ?
Here are some troubleshooting steps you may want to try:
- Make sure you have installed the drivers for your Webcam following the procedures listed in the Installation section of your manual. - Make sure the USB connector for your Webcam is properly and securely connected to an available USB 2.0 port on your computer. - Make sure the "Preview" option is checked and enabled under Options in the AMCAP software. - If the problem still occurs; exit the AMCAP software (or the application you are attempting to use with your Webcam), re-connect your Webcam to your computer, and then start the AMCAP software again (or the application you are attempting to use with your Webcam) - If the problem still occurs; please check and make sure that you have properly configured the video and audio sources of the program that you are attempting to use with your Webcam. - Restart your computer and try to use the webcam with your messenger program
Mar 30, 2011 | Gear Head Computers & Internet
I can't install windows live messenger, it encounter a network error while attempting to read from the file C:\WINDOWS\Installer\Messenger.msi
I found the site below and thought of your situation. Here is the message I received:
"Network error occurred while attempting to read from the file:
C:\\WINDOWS/Installer/Messenger.msi
Please close all other open programs, and then try again. It looks like another program is preventing the installer from working. hr.0x80070643"
If it's the same message, and you haven't found a solution yet, then this will do the trick. Although it's an older post, it works just fine for the current 14.0.8117.416 Messenger update issue:
http://www.pcadvisor.co.uk/forums/index.cfm?action=showthread&threadid=346865&forumid=1
Scroll about halfway down the page. Look for Microsoft Customer Support (Joan, Technical Support, Live Essentials):
Note: For the Windows Installer Cleanup Utility, I downloaded from this link (you'll want the latest version wherever you get it - 2.5.0.1):
http://www.softpedia.com/progDownload/Windows-Installer-CleanUp-Utility-Download-18442.html
Jan 23, 2011 | Computers & Internet
What would be stopping the drawer that you put CDs in from opening
there is a tiny hole below the drawer, stick a paperclip in there, sometimes u have to push quite hard but it should pop open. it may just be jammed, sometimes this can fix that.
Mar 18, 2010 | E-Machines eMachines Desktop PC
CD drawer cover broken - can it be repaired
When you say "cover" do you mean the bit of edge that you can see from the outside?
There is a tiny pinhole on that edge and I wonder if beyond where the broken edge ought to be, if you look you may see the inside of that pinhole that you can insert a straightened paperclip that makes it open.
In windows explorer where you see the drive under Computer, when you right click the mouse, you get the option to eject; this makes it open.
Oct 31, 2017 | Packard Bell GCD-R580B (gcdr580b) Internal...
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Program will not open
If a program will not open
1. uninstall the program from the add/remove
2. attempt to reinstall the program
3. attempt to run the program
4. if the program will still not open go to step 5
5. Some programs may be incompatable with your operating system and fail to open, if you have windows XP or vista you can right click on the executable
an executable (file) causes a computer to perform indicated tasks according to encoded instructions.
and click the compatability mode tab , then change what operating system is reported to the program, then hit apply and attempt to run the program again.
6. if after changing compatability setting of the to windows 95 the program still does not open
change the compatability to windows 98/windows me , hit apply and attempt to run the program again.
7. if after changing the compatability mode to windows 98/windows me , and your program still does not open , change the compatability setting to windows NT 4.0 (service pack 5), hit apply and attempt to run the program again.
8. if after changing the compatability mode to windows NT 4.0 ( service pack 5 ) and your program fails to rurn , change the compatability mode to windows 2000 , hit apply and attempt to run the program again.
9. if after changing the compatability mode to all of the available settings your program still fails to run , you may have a corrupt executable or an executable that is not compatable with your operating system.
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Computers & Internet
Lite On LTC-48161H CD-RW/DVD-ROM Burner Logo
66 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
