Question about Brother HL 1440 Laser Printer
Brother 1440 has all lights on, and the printer will not print. I took the cartridge out and slid the drum unit corona wire several times; when Ireplaced the drum unit and closed the door the lights did not go out and printer still is not working
  • Craig Gillette
    Craig Gillette May 11, 2010
    You need to hold the go button and see which lights are on, that tells what the error is, the owners manual tells what the lights mean, but if you don't have the manual, let me know which lights and I'll tell you the error.
    President:
  • 1,961 Answers
Needs reset procedure
There's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Posted on Nov 21, 2010
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Tip
How to clean the corona wire on Intellafax 2800,2810, 3800 machines
Does your brother printer or fax machine have bad printing such as very light print or spotty print. If you have these problems chances are you have a dirty corona wire. The corona wire is used by the printer to put a charge on the paper so the toner is attracted to it in the pattern that the laser draws out. Below are the directions to clean the wire.
1. Open the front cover and pull out the drum unit and toner cartridge assembly.
2. Clean the primary corona wire inside the drum unit by gently sliding the blue tab from right to left several times.
3. Return the blue tab and click it into the Home position.
4. Reinstall the drum unit and toner cartridge assembly in the MFC/Printer.
5. Close the front cover.
Be sure to return the sliding blue tab back to the home position next to the arrow or you will have dark streaks on your printouts
on Dec 09, 2009 | Office Equipment & Supplies
Corona wire problem
Hi, you can clean the corona wire easy, just follow those steps:
1) Turn of printer power and unplug all cord including phone cord.
2) Make sure the scanner is closed, then lift open the top cover by its handle.
3) Remove both the drum unit and toner cartridge assembly for the color desired to be replaced.
4) With the drum unit removed, push down the GREEN lock lever to remove the toner cartridge.
5) Slide the GREEN tab left to right several times to clean the unit's primary corona wire.
6) Before installing new toner cartridge, shake it from side to side to distribute toner.
7) Remove protective cover from cartridge.
8) Insert cartridge into drum unit until it snaps in place.
9) Ensure that you are inserting the correct color toner cartridge into its proper place and then slide the drum unit into the printer.
10) Close the top of the machine and then reconnect all cords; turn on power to ensure proper installation.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
I have a Brother HL 1440 Laser printer & I've put in a new toner cartridge. When I try to print, I get 1 line of symbols at the top of the page. I haven't replaced the drum in 10 years...could the...
The first thing I would try is to fix the corona wire. Here is a link to Brother's website outlining the process (clean corona wire).
What you need to do is pull out the drum and look for a blue tab on the top of the cartridge. Slide that tab back and forth along the wire and see if that clears things up.
I have had some luck cleaning the drum when I get black streaks but I have also hear this can be dangerous and make the problem worse.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000200/000008/faq000208_022.html?reg=us&c=ca&lang=en&prod=mfc7340_us_as&Cat=7
Jan 31, 2011 | Brother HL 1440 Laser Printer
There is a massage in red that reads drum error
Brotherstrongly recommends that customers do not use generic drum units and/or tonercartridges, or refill their Brother toner cartridge. Each Brother laser printeris designed to work at pre-set temperatures that are matched exactly to each ofour individual toner formulations. Each individual component is designedto work with the other to ensure quality and reliability. Using non-Brothersupplies may affect the hardware performance, print quality, and machinereliability. The Brother limited warranty does not apply to any problem that iscaused by the use of unauthorized third party drum units, toner cartridges, ortoner. Turn off the printer power switch. Press thefront cover release button and then open the front cover. Hold the green handle ofthe drum unit. Lift the drum unit up and then pull it out until it stops. Hold the handle of thetoner cartridge and pull it out of the drum unit. Repeat this for all the tonercartridges.
    • I recommend that you place the toner cartridge on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
    • DO NOT put a toner cartridge into a fire. It could explode, resulting in injuries.
    • Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    • To avoid print quality problems, DO NOT touch the shaded parts shown in the illustrations.
Push to release thelatches of the white corona wire cover (1), and then open the cover. Clean the corona wireinside the drum unit by gently sliding the green tab from left to right andright to left several times. Be sure to return thetab to the home position (1). If you do not, printed pages may have avertical stripe. Close the corona wirecover. Repeat steps 4-6 to clean each ofthe remaining corona wires. Hold the handle of the toner cartridge and slide the toner cartridgeinto the drum unit. Make sure that you match the toner cartridge color to thesame color label on the drum unit, and make sure that you fold down the tonercartridge handle (1) once the toner cartridge is in place. Repeat this for allthe toner cartridges. Put the drum unit backin the printer. Close the front cover ofthe printer.
Nov 16, 2010 | Brother HL-4040CN Laser Printer
A white piece of paper is printing out gray....think the toner is ok as the ink is black...something need to be cleaned?
Two things can cause this type of problem, 1 bad drum unit or 2 dirty corona wire.
HTML clipboard Below are the directions to clean the wire.
Be sure to return the sliding blue tab back to the home position next to the arrow or you will have dark streaks on your printouts.
If this does not solve the problem then you will need to replace the transfer drum in the printer. The part number for the drum is DR-400 or DR400.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
May 14, 2010 | Brother HL 1440 Laser Printer
Printer prints 3 large ink blotches on long side of paper. New print cartridge in printer. Problem started with old cartridge and did not change with new cartridge. I slid the corona wire on the drum but...
you may insist to clean the drum part. Your problem is in that area. Or try to change the drum unit with another one from the other printer if you have one. You can use an vacuum cleaner to absorb the toner inside the corona part. You should be careful at the corona wire.
Oct 05, 2009 | Brother MFC-8460N All-In-One Printer
Brother 1440 laser printer. Started printing with
may some dust in corona ware or drum clean the drum.
Apr 06, 2009 | Brother HL 1440 Laser Printer
Printer not working
On this printer, the alarm and data lights mean that the toner cartridge is empty. When you replace the toner, be sure to slide the corona wire cleaner across and back. This is the small light blue plastic piece on top of the drum cartridge. You'll see a small arrow in the plastic. Just slide it back and forth once or twice each time you replace the toner cartridge.
May 11, 2008 | Brother HL 1440 Laser Printer
Brother HL 2040 out of paper light stays on
Sounds like it sensed this as a paper jam. If it is your Paper LED that is stuck on:
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Mar 14, 2008 | Brother HL-2040 Laser Printer
Brother HL 1440 Laser Printer Logo
320 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
