Question about Microtek C783GM 17" Flat Panel LCD Monitor
I have a Microtek 710S which suddenly will not show anything other than a black, blank screen. When I turn on the button in the bottom center of the frame, it alternately changes color every second or two. I'm in the middle of a huge project and a looming deadline. HELP!!! acblunt@austin.rr.com R. Blunt 512-336-1260
    President:
  • 1,884 Answers
Does it show any sign of life when you poweron the PC? With the PC powered on, remove the data cable of the monitor (yes the D plug) from the PC and insert it back. See if there are any signs of life. If there are any signs of life, reboot in safe mode by pressing F8 at bootup. If it boots in Safe Mode, then go to Control panel->Display->Settings->Advanced. Remove the Monitor and let windows detect the monitor. Same thing can also be done from Control Panel->System->Hardware->Device Manager-. Monitor. Remove the monitor and from Actions select Scan for New HW.
Posted on Oct 02, 2009
My 710s Microtek monitor won't turn on. The led at the bottom turns orange as usual but doesn't continue to turn blue. It did yesterday. I tried connecting my monitor to my graphics card but that doesn't...
I would disconnect the cable from the computer, turn the monitor on and see if a small box with a message comes up that there is no input into the monitor..if so..its video card inside the computer or the cable.. or a driver...just guessing here...
May 28, 2014 | Computers & Internet
My Microtek 710S Monitor screen goes black if left unattended for one minute. What do I do to keep this from happening?
Check the power setting of your PC.
  • If you are on windows;
  • Click on start button
  • If you have vista or windows 7, type "poweroptions" into the search bar.
If not, open control panel and find the power options inthere
  • In "power options" you can change when the displaygets turned off and when your PC will go to sleep, just change these settingsto the time you want, e.g. 2hours
I can offer support for other OS if required
Mar 02, 2011 | Microtek 710S 17" Flat Panel LCD Monitor
I have a microtek 710s monitor, that powers on but
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Computers & Internet
I have a microtek 710s monitor, that powers on but the screen remains blank. Please help.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 28, 2010 | HP Pavilion F1703 17" LCD Monitor
Dialogue box in the middle of the screen
Out of range usually means that the computer is trying to use a resolution that is unsupported by the monitor. Try loading the PC in safe mode (for windows, press F8 before windows loads) and change the desktop resolution to 800x600, which is supported by pretty much any monitor. Restart the computer normally and you should get your video. Once inside windows you can experiment with different resolutions, and when it goes out of range, just wait 15 seconds for it to go back to 800x600.
May 15, 2009 | Microtek 710S 17" Flat Panel LCD Monitor
Help !! ,Microtek scanmaaker 3840 problem
maybe you have to clean up your scanner.. and ur settings of scanner might have the wrong configuration....
Feb 24, 2008 | Microtek scanmaker 3840
Microtek C783GM 17" Flat Panel LCD Monitor Logo
91 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
Michael Deni
Level 1 Expert
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
