Question about Bionaire Humidifiers
I bought an old bionaire clean mist 3, and don't know much about it. does it have a filter and should it shoot out cold or hot air
5 Suggested Answers
SOURCE: My Bionaire Humidifier
From the user manual (which is online)
2. Clean the base by partially filling
it with one 8-oz cups of undiluted
white vinegar or by using Cleanse
CleanTM Solution (DMS216) by the
manufacturer. Leave this solution
in the tank for 20 minutes, while
cleaning all interior surfaces with a
soft brush.
Posted on Jul 09, 2008
SOURCE: replacement filter question
Filter part number is BCM100. Filters are sold at Sears. Also available online. Part number is listed on bottom of humidifier.
Posted on Dec 29, 2008
sabharish
  • 297 Answers
SOURCE: HAVE LOST OPERATING INSTRUCTIONS FOR BIONAIRE
Here is the download link for the instruction manual :
http://www.bionaireuk.co.uk/Manuals/MANUALS/BWM5075C-IUK_43_7594830.PDF
It wud be great if you rate this solution!
Thank you!
Posted on Apr 03, 2009
  • 114 Answers
SOURCE: Family Care cold mist humidifer
cool mist humidifiers don't put out any mist. only the warm ones do. now if you put your hand over the area where it's coming out for about 2 minutes and take it away your hand should feel damp. almost clammy. if it feels like that the unit is working fine. so your not doing anything wrong. if you have any other concerns please let me know.
Posted on Aug 26, 2009
Bionaire BT-200 ultrasonic humidifier have stopped misting, though I can hear a hum as though something is still working. I have two of these in the same state.
I have the same model; it has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up. The scale keeps the disk from vibrating.
Jan 24, 2017 | Bionaire Humidifiers
Where do I find a manual for the bionaire bcm4510-u? I would like to chance filter but no access that I can see...
You just lift up the unit and it will separate from the bottom. No screws holding it together. I had the same problem.
Jan 09, 2011 | Bionaire Cool Mist BCM4510U Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
HUMIDIFIER IS VERY NOISY AND MIST SPRAYS FROM ONE SIDE ONLY
You should have bought a Cleanaer! It's totally silent, reaches all corners of the room with its patented LiquidIon technology not only takes the bad particles from the air, but locks them out for good so they do not reenter the airspace when you cross the room or disturb the furnishings.
Feb 15, 2009 | Bionaire Humidifiers
Replacement filter question
Dec 04, 2008 | Bionaire BCM7204-U 3 Gallon Humidifier
soft brush.
May 19, 2008 | Humidifiers
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Feb 07, 2008 | Bionaire Warm Mist BWM0400-U Humidifier
Need help humidifier doesn't stay on
I've had this problem before and with mine, the issue is the water is not making its way into the correct reservoir on the bottom of the machine. With experimentation, I discovered that my tilting the machine slightly upwards on the righthand side corrects the problem (i.e. put something aprox. 3-5mm thick underneath the right side of the machine). You will hear that the water "move" to the left side of the machine and thus ensuring proper operations. I think this is a design flaw (for some machines) as clearly I have the same problem too.
Pc
Dec 19, 2007 | Bionaire Cool Mist BCM4530 Humidifier
Humidifiers Logo
213 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
