Question about SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip is stuck on connected.
I ejected it but when I pulled it off, the Sansa Clip screen just says Connected, but it's obviously not doing anything.
BTW, I have an iMAC if that matters.
Thanks
  • 1 more comment
  • chan2007 Dec 22, 2007
    I have the same problem , anybody knows what to do?
  • Lawdoc Dec 28, 2007
    BSOD on my Sansa clip just like everyone else. Is there an official work around?
  • Quackfan Jan 01, 2008
    I finally got mine too, but had to erase everything in the process.  I finally got it turned off by holding down the power button.  Then I put it in the lock position.  Then I held the main select button down, while plugging it in.  Then I west to disk utilities as erased it.  The Sandisk tech support line helped talked me through it.  Then when it happened to my son's (the other on is my daughters), he took it to Best Buy and they got his going.  They've both had problems since though, and I think it's because I have a Mac.  Even though various websites and the staff at Best Buy had told be it was Mac compatible.
    Hope this helps.
Hey it happened to me before for about 10 minutes try to hold the power button to off for a bit then let go if it doesn't work try it again...
i got mine on the 5th try... it takes patience
Posted on Dec 31, 2007
How to fix a sandisk fat is corrupted please recover fat
You could try the following:
Start with the Clip turned OFF. Slide the power switch down to the HOLD position. Press and HOLD the center button depressed until it is recognized by the PC- give it a few seconds.
The Clip's display will state "connected" with the device now in MSC mode.
You can now repair the File Allocation Table (FAT) using Windows' chkdsk utility.
Open My Computer and find the Clip a listed under "devices with removable storage" as a flash drive. Let's say it displays as E: SANSA CLIP for example. Our assigned drive letter is E:
From the Run box under Start, enter cmd and press Enter. You will get a DOS window.
Enter chkdsk E: /f and press Enter. The /f toggle tells the utility to fix the errors.
After clicking on the Safely Remove icon in the taskbar, or right clicking on the Clip and selecting Eject, unplug the Clip.
Try powering it up again, and see if all is well.
I found this at: http://forums.sandisk.com/t5/Sansa-Clip-Sansa-Clip/FAT-is-corrupted-On-Clip-4G/td-p/250798
Dec 31, 2014 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
http://www.sansa.com/support/sansa_clip/faqs
good luck
Joe
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip jammed
Rebooting the device usually helps with this.
Any time it's 'stuck', you can do a soft reset (reboot) by holding the power/hold button up in the 'on' position while pressing the center-round button for a few seconds.
If it defaults to off, it should restart normally by using the power-on switch.
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
I connected my new sansa clip player to my computer but its not letting me get in the folder.
Double-click My Computer, double-click the Sansa icon - you will now see the folders
The detailed instructions are in the user manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
xx
Dec 25, 2008 | SanDisk Sansa Clip MP3 Player
When i plug my sansa clip in the usb it wont pop up.
change the cable then check , or check in some different system
Nov 27, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip not coming on
try turning it o while its on the computer
May 30, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2g breakdown
Get the firmware update from Sansa's website, and then restart your computer.
http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 15, 2008 | SanDisk Sansa Clip MP3 Player
Hello
hold the off switch until it shuts off. than put it back into the computer and eject it. it should refresh normally and quickly
Feb 28, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
1,786 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
