Question about Samsung SL30 Digital Camera
Screen flashing different colors
I just got this camera and when I put the batteries in and tried to set it up, the screen kept flashing different colors and won't turn off. I tried another set of batteries and had the same problem.
I left my camera in my car for a short time then took it out to video nnow it has colored lines on the screen and its all blurry
u shouldnt hav kept it in car...the interior tmp of the car raises due to green house effect...excessive heat exposure might hav damaged ur cam...remove the battery try to keep it untouched for a week...if the porblem persists then replace the lcd....
May 23, 2014 | Canon FS100 Flash Media Camcorder
When trying to take a picture or record a movie, the screen is a solid light pink.
try an sd card from another source. the format function of the camera should be used to prepare the sd card for the camera before you take pics with it. this may be a format issue with nintendo. format will erase all images on card, so save them first somewhere else.
Jun 14, 2013 | Cameras
Hi My digital camera the Nikon coolpix s3000 kept flashing batter exhausted but it wont charge by the computer. How do i fix or charge my camera?
Not all computer USB ports put out enough current to charge batteries, especially if you're going through a hub. Try a different USB port if one is available. Otherwise, plug the supplied AC charger into a wall outlet and use that.
Dec 08, 2010 | Nikon Coolpix S3000 Digital Camera
Fuji S7000 shuts itself down...without a reason
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Dec 27, 2009 | Fuji FinePix S7000 Digital Camera
Viewsonic N2750w flashing different colors on screen
did you get any answers? I have the same problem.
Jul 06, 2009 | Televison & Video
Flash setting doesn't work
Does your camera gave a small battery in place somewhere that is used to maintain the date and time settings? (it is generally a watch battery type small flat silver disk.) You should not have to reset time and date after each battery change.
Many digital cameras eat up batteries quickly, especially when using the flash alot., that is why it is important to use good quality rechargeables whenever possible.
Jun 19, 2009 | Fuji FinePix 3800 Digital Camera
Displays all white in all modes. Kodak V570. Turn the power on and all I can see is white. I have tried a different battery an no battery, just power cord. I know the camera good enough I can go into the...
displays all white because all the color screen have RGB mode if any of mode's are not work correctlly it's mean's color chip was fail and not working. u have to repair ur camera and change ur display screen.
Mar 01, 2009 | Kodak EasyShare V570 Digital Camera
"turn camera off then on again" message
There could be a short in the battery contacts in your camera. You should inspect them for corrosion or oxidation.
Jul 16, 2008 | Panasonic Lumix DMC-LC80 Digital Camera
When I try to charge the battery the light just flashes and the charger does not work.
Hi, I had the same problem!
Had not used my camera for a while so I decided to but my battery on charge, once in the charger the orange light just kept flashing so I left this in "flashing" for a good hour or so.
I removed it and then replaced it, and it was still flashing so I decided to get a new battery (£40!).
I put the new battery on charge over night and it charged great, so I thought I would re-try charging my old one before I sent it away for recycle, and guess what the orange light stopped ON and it was charging!
Not sure what happened here, it was either charge the old for an hour with light flashing and then remove and leave over night and re-try OR insert a good battery to re-set the charger?
But I now have 2 good batteries.
Hope this helps :)
Apr 23, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
My screen is white
I would suggest trying a new set of batteries. Probably won't make a difference but its worth a try. Screen will not come on after taking a picture to preview it if the battery is getting low but will work looking through the pictures. try, also, different memory card
Jan 07, 2006 | Pentax Optio S5i Digital Camera
Samsung SL30 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
