Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My refrigerator/freezer unit is not getting electricity
My refrigerator and freezer unit will not get any electricity at all. The circuit breaker has been reset. What do I do from here? I can't find any fuses if there are any.
  • milten1
    milten1 May 11, 2010
    check your wire it may be cut or crimped
    if thats ok you need to check the compressor relay and over load
    make sure the temp setting is not set to off
    President:
  • Amana Master
  • 1,922 Answers
Check your thermal fuse by compressor, then see if you can take the cover off the contactor and with an insulated stick manually start the compressor by pushing in on contactor unit on the side of the compressor
Posted on Oct 05, 2009
Refrigerator was not running and was making a clicking noise. We may have a low electrical power problem throughout the house. Imhae thrown the circuit breaker to stopthe clicking.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
I have a Maytag refrigerator that continues to trip the GFI circuit breaker when plugged into the wall outlet. Have replaced the electrical outlet, replaced the GFI outlet and replaced the refrigerator...
heatman101
Sep 05, 2011 | Maytag MBF 2256 Bottom Freezer...
Suddenlly stopped working
Hello tru..... if the entire appliance stopoped working pull it out and test the outlet that it is plugged into. To test that, plug a lamp or a blow dryer into that outlet and see if you have power to that point. IF you do not have power, go to your electrical panel and check the circuit breaker or the fuse. To check the circuit breaker, turn it all the way off and all the way on twice. With a fuse that is blown you must replace it. Joe
Thanks for choosing Fixya!
Jan 11, 2011 | Maytag MSD2454G Side by Side Refrigerator
My refrigator/freezer is kicking off the circuit breaker each time I plug it in
Two obvious possibilites. One, it may not be the only unit on that circuit. If you have a 15 or 20 amp breaker, and have more than one unit like this, you are pulling too many amps for the breaker.That happens frequently. The other possibility is a dead short somewhere in the unit. Try plugging it in to a different outlet that you know has nothing else on that circuit. If it comes on and runs, You need to run a didicated circuit for this freezer only. A dead short in the machine will kick any outlet that it is plugged into. You will have to isolate each circuit in the freezer to find which one is grounded out.
Sep 15, 2010 | True T-23DT Bottom Freezer Refrigerator
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
GFCI on refrigerator circuit cuts off.
Yes. Refrigerators should not be on gfci protected circuits. They should have a dedicated 120v circuit .If your kitchen is new enough to be wired with gfci breakers ,it should also have an outlet dedicated for the refrigerator.
Dec 05, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Unit not running, not cooling electronic
To operate, a refrigerator needs electricity. If the refrigerator's light doesn't work and it's motor doesn't run:
1) Check the power. Make sure the receptacle works (plug in a working lamp or a circuit tester). If the receptacle doesn't work, check for a tripped circuit breaker or blown fuse.
2) Be sure the cold control is turned on.
3) If you discover that the refrigerator is plugged into a working outlet and the cold control is on but the device shows no signs of life, leave the door closed to retain the cold air and call an appliance repairperson
Jul 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator (Whirlpool) increase in electricity usage
very doubtfull fridge fault would double elec consumption. look at rating plate and see how many watts then equate this to light bulbs. average light bulb is 60-100 watts (uk). does circuit breaker you turned off only control the fridge?
Mar 21, 2007 | Frigidaire FRT15G4B Top Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
112 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
