Question about Desa International HRC201-4 Remote Control
HRC 200 does turn on flame.It can be turned on manually only
  • 832 Answers
The sensing device on the remote does not reflect the right room temperature to trigger or activate the remote igniter for the flame.
"The remote igniter is triggered by the room temperature". I'll get
back to you if the there's a way we can reset the trigger temperature.
Posted on Oct 23, 2009
  • rolando ingking Oct 23, 2009
    I have tried to research but to no avail, the preset temperature of 66F
    cannot be changed. However, it will work once the temperature reaches 66F. Be sure that the batteries works well. You can send in
    your comments via e-mail. God bless you.
I have a pair of pentax 10x42 DCF HRc binoculars that will not focus properly througn the right eyepiece. Just wondering if this is a common problem and is it worhtwhile getting repaired
The binos will rack focus both at the same distance, you need to rack focus left side to distant image with left eye only, then turn diopter focus to focus right eyepiece. Diopter focus is thinner wheel behind focus wheel
Aug 15, 2015 | Pentax DCF HRc (10x42) Binocular
Tip
How to diagnose a propane BBQ flaming at control knobs
WARNING: this test can be dangerous; do it only if you know what you are doing!
I turned on my two burner propane BBQ. The left side worked OK but flames started coming out of the control knob (front area) on the right, and the right side burner was not lighting.
This is obviously gas leaking out of the front area. If the flames go out when you turn the knobs off then the leak is after the valves, controlled ny the knobs. If the flames stay on and only go out if you turn gas off at the tank then the leak is at the pipe entering the controls. In my case the flames went out with the controls, so I looked underneath. I slowly turned the knob down and saw that the flames (therefore the gas) was coming out of the air regulator/entry hole. I knew at once that the pipe going to the burner must be blocked. Sire enough, when I removed the burners I saw that an insect built a cocoon in the pipe. Clearing it solved the problem.
on Jun 11, 2015 | Cuisinart CGG-200 All Foods Propane BBQ...
Flame can't be adjusted ,starts off mid level and gets smaller as i turn on the other burners.heat only goes to 200.this problem only happens when the temperure is 65 and lower.changed regulator and had...
Turn the tank valve off and disconnect the grill hose from the tank. Wait five minutes and reconnect the hose to the tank. Turn the tank valve On VERY, VERY SLOWLY. Once the valve is completely open, light the burner farthest from the tank and turn the flame to high. Move to the next burner and repeat, until all the burners are lit. Are all the flame heights back to normal? If so, problem solved. If not, repeat the procedure again. If that doesn't solve the problem after the second attempt, it's time to replace the grill hose/regulator. You can purchase one at any home improvement center or hardware store that sells grills. Be sure to take your old one with you, to get the proper length and size.
Hope this helped solve your problem.
Mar 06, 2011 | Brinkmann Grilling
Can't regulate burner temps. Only heating to 200 degrees.
When you turn on the burners, do the flames get lower the more burners you turn on, if they do you probably need a new regulator.
Nov 12, 2010 | Kenmore 16228 Grill
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
Need owners manual, Perfect Flame Grill, Model #E3520-LPG
I have a perfect flame gas grill E3520LPG and it takes a hour for it to heat up
Apr 11, 2009 | Grilling
I have a desa hrc 200 remote the room temp doesn't work
It cannot be repaired. Replacement parts are no available for this unit and it only had a 90 day warranty. You will just need to purchase a replacement. You can contact Master Parts at www.masterparts.net or by calling 800-446-1446. I hop this helps!
Jan 31, 2009 | Desa International HRC201-4 Remote Control
All-Pro 200 will not ignite.
It sound like you have either an ignition or 'dirty fuel' issue. The now Desa 'All Pro 200 T' that I have I fixed numerous times.. the approx $70 'ignitor'. But when the error code says flame' If you can tell that the thing started a flame... for a few seconds or at all.. then you can be sure that the ignitor is not the problem. .. yet. And that the flame is not a consistent lighted color.. which can meen diferent fuels mixed together..or water in the fuel. I'd try starting your heater with a high octane 'power boost' type fuel additive straight.. and then if it runs on that w/o a problem.. then you know its the fuel or fuel system.. Also you might check that the blue wire eye.. that 'looks at the flame' window is clean and wiped off with a clean cotton swab.
md
Nov 15, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Desa International HRC201-4 Remote Control Logo
296 people viewed this question
Top Desa International Televison & Video Experts
Electro Med Services...
Are you a Desa International Televison and Video Expert? Answer questions, earn points and help others
