Question about Sharp ANXR1LP Projector Lamp for XR1X,XR1
Flashes change lamp after a couple of hours run
Flashes "change lamp" after a couple of hours run time. I do not have the projector sitting on anything hot, and it has plenty of room around it for cooling.
I got a new lamp and it lasted about 40hrs run time total. I use it to watch 1 DVD each evening. After approx 20 hours of run time since new, it would show "change lamp" in yellow occasionally upon start up. Last night it changed to a red "change lamp" annunciation and shutdown the projector.
Thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Posted on Sep 28, 2016
dhiman
  • 115 Answers
SOURCE: XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Posted on Jan 21, 2008
  • 9 Answers
SOURCE: C20x lamp error
This is due to thermistor problem. Near to the lamp one thermistor will be there please check connectivity. if it is failed please change the same.
Regards,
prakasam
Posted on Apr 16, 2008
  • 4 Answers
SOURCE: sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Posted on Apr 19, 2008
SOURCE: PG-C45X projector wont power on
To solve this problem, simultaneously press the "Input", "Enter", and "Undo" buttons. While holding these buttons, press "On". When the project turns on, you should see "LAMP 100%". This indicates that you have successfully reset the lamp life timer.
Posted on Jun 06, 2009
  • 150 Answers
SOURCE: Recently I was using my xv-z90u, I started the
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
Posted on Jan 17, 2010
Lamp wont ignite.lamp light red flashing.
Before changing lamp use a canister of compressed air to remove dust specially inside the projector when lamp is away.
Dec 13, 2013 | BenQ PE7800 Multimedia Projector
I have a dell 1209s projector and the temp symbol flashes. I dont know if I need a new lamp or what? Help me? thanks
Check the lamp cooling fan of your projector. maybe its has some problem. its not running at the correct RPM. that's why the lamp get over heated and the temp lamp flashes.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
Also try to reset the lamp hour of your projector. you can see the option for reset the lamp hour in the menu. Please not one thing lamp reset is recommended only after replacing the lamp.
ok
Mar 10, 2011 | Dell 1209S DLP Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
Aug 27, 2009 | InFocus IN72 Multimedia Projector
Working but lamp warning on screen,lamp led flashing
Press < and > and Power buttons at the
same time on the projector to reset the
lamp hours counter
May 12, 2009 | Mitsubishi SL1U Multimedia Projector
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
My Panasonic PT-LB50U LCD projector flashes red lamp indicator and will not light up. I replaced the lamp and it still will not light. The old lamp only had 20 or so hours on it and it does the same thing....
this worked for me what i did is: turn on projector then undo the light panel when its on the projector then will cut off, now the light panel pushes down on the hidden safety switch take a screw driver and push down on the switch, the projector will turn on then wait for about 8 sec then release the projector will turn off, repeat step several times until the light flickers, then do a couple more times and the light should come on and should stay steady turn off and let cool for 10 min, this worked for me hope it works for you!
Aug 12, 2008 | Panasonic Televison & Video
No image, lamp light blincking red
I have a 3 yr old AE900U dont know exact hours but prob at least 2000 hrs. about every other start up, the projector would flash little box; (replace lamp now). now a month later lamp wont come on. So this is prob the normal way a lamp will die. anything else might be another problem.
Jul 23, 2008 | Panasonic PT-AE900U Multimedia Projector
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Sharp ANXR1LP Projector Lamp for XR1X,XR1 Logo
196 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
