Question about HP Computers & Internet
Power supply on HP MediaCenter m7664x
I received an error using Excel and my machine froze. I finally wa able to turn off the power but when I tried to reboot no power, the green light on the back of the power supply is on but I get no power to any of my devices ie mouse, motherboard, hard drive, network card ... my power suppley is Hipro HPD3057F3-R (300w)
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
Switch on and check the fans on the PSU and CPU are running. If not you may want to try a replacement before you go any further.
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Oct 10, 2009
My cpu not on
Posted on Sep 20, 2010
  • 832 Answers
Start with checking if the power supply fan is working. If not, you replace your power supply, and switch your PC on, and find out.
Then, send in your e-mail so we can further assist you. There's a
good chance that you will be able to reboot your PC. If ever, you
will be able to reboot it, run your antivirus software. Then, open tune
up utilities 2009 to get rid of unnecessary file and optimize your PC.
In case you don't have it, you can download it from the internet.
How do I replace the power supply, and can I use one from an SR1738NX?
Before attempting to replace the power supply, I would check to see if they are compatible. I would check to see that the wattage of the Compaq Presario SR1738NX is the same or larger than what is in your current computer. This information should be on the label of each power supply.
Next, I would check the connectors to ensure that all the connectors that are currently connected exist on the old power supply.
Next, take pictures of all the power supply connections on your new machine.
Finally, remove the power supply from your new computer, replace it with the power supply of your old computer, reconnect all of the connectors, and turn on the machine.
Good luck,
Paul
Dec 21, 2015 | HP Compaq Presario SR1910NX (EX310AA) PC...
Wont send message. Error no 442
This error indicates that the receiving machine (receiver) cannot receive the fax you just sent. The reasons might be unexpected shutdown of the machine (Receiver's machine) just before it completely received [or partially printed] the file you had sent or power failure during the process.
Another reason is, when we send color fax from Hp machine to another Machine (non-hp), this happens due to incompatibility issue.
Solutions are;
1. Restart both the machine after deleting the recently sent/received fax.
2. Send black and white only, not color.
3. Try again after the phone line seems not much busy which means when there's better transmission capability.
Good luck.
Thanks for using FixYa.
Jul 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
solution:
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
HP c6150 all in one error message Oxc19acff Ink System Failure. Replaced Yellow ink cartridge an still receive error.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP OfficeJet 7110xi
finally you can try a reset on the macj\hine using the # and the number 6 buttons(holding them down and then plugging in the power cord at the back of the machine).If it still gives the same error..try the same with the # and 9...same problem comes up....service the printer
Jun 24, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Computer will not boot up
need to reinstall windows it is corrupted
Mar 27, 2009 | Dell Dimension 2400 PC Desktop
HP power up issue
hi
you will have to remove the power cable and hold the power button for 7 sec w/o power cable and then try connection the power cable and turn on
2) reset the power connector on the mother board and try it
3) remove the memory and chk if you could listen to the beep if yes the mother board and power supply is fine so try removing the pci cards if any
Try those things
Regards
Samson Ved
Dec 10, 2008 | HP Media Center m7260n (EG642AA) PC...
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Camera won't turn on
I am assuming that the power does not go on or it immediately turns off as it is turned on.
Try the docking station or the 3.3 AC adapter to the camera. Plug that in to live power. If you hear the lens motor (by default the lens is retracted to closed position when plugged to AC power), then the camera is operational. If not, there is power failure with the camera.
If the lens motor work, then try to turn the camera while plugged to AC power. If it turns on, then there is something wrong with the battery or with the chamber. If the camera does not turn on, then check the button board for a bad power switch.
Check the LCD closely under a bright light when you do this test. You may see a faint a flash of display that disappears. I have not figured out what causes this. This would mean that camera power supply is working but nothing is telling for the camera to stay on.
Aug 02, 2008 | HP Photosmart M407 Digital Camera
No power
the power supply should be replaced.
Go to Blinking LED section.
Here are steps to take from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=449144&lang=en
Jan 07, 2008 | HP Pavilion a805n (PS519AA) PC Desktop
Computers & Internet Logo
519 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
