Paper output Slot Paper Jam
I've checked the Paper Output Slot, thoroughly, and there is no paper jam. And it continuously says there is a paer jam...
  • 78 Answers
Use advanced couple sheet by the unit if something hangs it unit routed it and check sensivity of your input and exit sensor and cleanness also
Posted on Oct 10, 2009
    Problem Solver:
  • 31 Answers
Try to advance a couple sheets through the unit - to see if anything hangs it up as its routed through the unit.
Posted on Oct 09, 2009
    Problem Solver:
  • 7 Answers
Check and make sure that the exit sensor is clear an free moving.
You can usually move it with your finger up and down.
sometimes they get stuck in the up position.
Support code 1313 on MG5422
The paper is inside the machine of the paper feed route. Also one small piece of torn paper over a sensor with say 'Paper Jam'.
Canon Knowledge Base - Paper Jam - Support Code 1313
https://support.usa.canon.com/kb/index?page=content&id=ART143004If the paper jams as the machine pulls in the printed paper, remove the paper following the procedure below. Important. If the printed paper piles up on the paper output slot, the machine may pull it in and the paper is jammed inside the machine. Remove the printed paper from the paper output tray before it amounts to 50 ...
See the videos. It is the same for all Pixma.
pixma mg5420 paper jam Google Search
Mar 10, 2018 | The Office Equipment & Supplies
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
How do I remove paper jamed in the printer?
Paper Jam :
Cause 1 : Paper jammer in the Paper Output slot or the Rear Tray.
Action : Remove the paper following the procedure below.
a) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
*If you cannot pull the paper paper out, turn the machine off, and turn it back on. The paper will be ejected automatically.
b) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step a), all print jobs in queue are canceled.
Reprint if necessary.
If you canot remove the paper or the paper tears inside the machine or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Cause b)Landscape credit-card-size paper jammed inside the machine.
Action : Do not load credit card-size paper in landscape orientation.
Slowly pull out the paper from the Tray and remove it.
If you canot remove the jammed paper or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 25, 2009 | Canon PIXMA MX300 All-in-One Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer jam upon exit
Check the paper output area ( around the output rollers) for a small piece of paper. You may need to disassemble the output paper assembly, and clean the rollers, or replace the paper output assembly.
In reality, what you have is one part of the printer trying to "push" the paper, while another part of the printer is trying to "pull", resulting in the wrinkle.. The problem may also be with a paper output sensor being stuck, which is why I suggest you check thoroughly for paper scraps in the output assembly.
Nov 14, 2008 | HP LaserJet 3030 All-In-One Printer
Paper jam
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
163 people viewed this question
k24674
jasbo
jasbo
