Question about Panasonic NN-T990SA Microwave Oven
Panasonic microwave, returns to clock setting after 3 seconds
I'm not sure of the model, but its panasonic brand, it shuts off after runnign just 3 seconds. I unplugged and plugged it back in thinking it was some sort of protection setting but it still does the same thing. Started yesterday, not sure of how old the oven is exactly - less than 2 years I think. If I were home I'd call the company! Any suggestions?
    Scholar:
  • 78 Answers
This sounds like one of two things to me it maybe if the unit has inverter on the front of it the magnetron or the inverter itself both repairs can be expensive if its both and that does happen around 80.00for the magnetron and poss not much change out of 120.00-150.00 for the inverter sorry its best with that fault to take it to a shop or call an engineer unless you are confident with this sort of unit its best left to a pro
Posted on Oct 23, 2009
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
Panasonic microwave oven cuts on for two seconds then shuts off
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Nov 03, 2011 | Panasonic NN-T994SF Microwave Oven
Oven only runs for 5 seconds no matter the time programmed in. the power level can be set and it does not matter, the oven runs for 5 seconds and shuts off.
I would need your full model number to help you best, but I'm guessing that at least it's a Panasonic?
If so, see
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
If yours is not a Panasonic, please create a new post with your brand and model number so we can help you.
Oct 10, 2011 | Panasonic NN-H264 Microwave Oven
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Turns itself off after only running 2-3 seconds
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
If yours is not a Panasonic, Please reply back with your brand and model number so we can help you.
Aug 08, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave cuts out after 23 secs
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Dec 15, 2007 | Panasonic NN-S550WF Microwave Oven
Scrape or fix? Panasonic inverter genius sensor 1250 watt
In most cases, this is a problem with the inverter but it may be a bad magnetron.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Microwave Ovens
On for 2-3 seconds and shuts down with slight wire burning odor.
http://froogle.google.com is showing this model selling for as little as $100. But as a technician, I have never cared for the inverter models. As complexity increases...
Mar 21, 2007 | Panasonic NN-T774SF Microwave Oven
Can't get past the "welcome" message.
Go to the page in the owners manual to set the clock first. Thats always the first thing to do. Good Luck
Aug 16, 2006 | Panasonic NN-H764 Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
237 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
