Question about Zanussi FJS1225W Front Load Washer
Washing machine dont have a garden hose anything else i could use instead?
    President:
  • 1,294 Answers
Problem not clear
Posted on Dec 21, 2007
My son took the pump of my washing machine to see if it was working as the water wouldn't pump out, since putting in back my machine is now not doing anything at all, even the lights are very dull instead...
did he connect the hoses right? theres really not much u can do wrong in taking out and putting back in? did the propellers move on the pump freely
Mar 29, 2015 | Washing Machines
Washer is full of water. drain is blocked with hair or lint i believe. washed some nasty stuff. wont drain. how do i clear the blockage? i think may be blocked inside washer. drain hose is very narrow...
If you can get a garden type water hose near there, try to carefully use it to blow the water backwards through the drain hose. Put the hose up to the drain hose end and wrap a rag tightly around it and turn the water slowley. This may free up any debris from the hose and pump. If anything comes out,clean it out of the tub before you turn it back on.
Sep 02, 2011 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 70 series ,overflows and wont go into wash cycle Have taken the level switch out and when i blow into the switch it does make the machine wash so i guess my question is: how does the machine...
While the unit fills the air pressure is pushed up the hose to activate the pressure switch. Make sure there are no pin holes in the hose, check that hose is secure to air dome on tub. If the hose has no holes or air leaks the issue would have tobe the pressure switch.
Jun 06, 2011 | Kenmore Washing Machines
My top load washer was in storage for a year. Now that it's out and I'm using it, the cold water comes out in a drip instead of how it should.
Check your hoses for signs of critters having moved into them while the washer was in storage. Remove the hoses and look in both ends of each. You can flush through the hoses by connecting to a garden faucet and discharging water through the hose and into a bucket. I say into a bucket so that you can see if anything was actually in the hose, or if you accidentally blow one of the screens off.
While the hoses are off, look in the holes where the hoses connect to the washer (These are the solenoid valves). If there are screens there, inspect them for debris, and clean as necessary.
This should get you going again.
Best regards, --W/D--
Jan 24, 2011 | Frigidaire FWSB5700DS Top Load Washer
Machine takes perhaps 45 min to fill with just hot water. It is not in the wall pipes - we had that checked.
On mine I turned off the water and removed the hose off the machine. I looked at the washer where the hose connects and it has a little screen to filter the incoming water. It was cloged with white stuff. I picked the screen out and cleaned it.
Maybe yours is the same thing.
Also I hooked a garden hose to the supply water and let it run full open to help flush anything from the water line.
Nov 03, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Hoover nextra washing machin3e , not draining
Yes Disconnect drain hose from the rear of washer. You will need to use special pliers that have notches in them to grab the hose clamp or you might need a Screw Driver if the hose clamp is a regular hose clamp. Remove clamp and flush washer hose with a high pressure hose or garden hose. Inspect drain where you took the hose off for any blockage. You might have to do this two or three times.Yet most of the time one time is good enougg. Good Luck!
Aug 28, 2009 | Washing Machines
Water from LG 30 pt dehumidifier drains into reservoir instead of running through garden hose into floor drain like it is supposed to. Have checked...no obstructions to garden hose. Very frustrating...must...
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
Jun 19, 2009 | LG DH30 GoldStar Dehumidifier
Check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
May 17, 2009 | Electrolux EW1000i Front Load Washer
HOW TO DRAIN WATER IF MACHINE SOPS AND WONT RESTART
I take it that you have tried rotating the cycle knob slowly through the point at the end of the wash cycle to the rinse cycle? On many machines, this will trigger the pump to drain the tub. Yet I am guessing that you have already tried that.
You could try running a garden hose from the machine along the floor and then outdoors. Next, take the end of the garden hose and place it into the top of the machine so that the end of the garden hose goes to the bottom of the tub. Feed in another five feet of garden hose into the machine so that this five feet is below the water level. Now, hold the palm of your hand over the end of the garden hose at the bottom of the machine and while doing this, pull out the extra five feet of garden hose and then remove your hand from the end of the garden hose. This should have "primed" the end of the garden hose with water so that the water will get sucked out of the machine and flow through the garden hose to the outdoors.
If this doesn't work, then you will need another person to **** on the other end of the garden hose in order to get the water to start flowing through the garden hose.
Apr 25, 2009 | Maytag MAH2400A Front Load Washer
Rotton egg smell
The smell is simply residual biological washing powder doing its job and eating away at the mess and muck in the tube (along with the smell of rotting bits of lint and other rubbish. Dragging the garden hose into the house and flushing the pipes out with some clean water under pressure may help. Also, you may find thattitting the machine on its hottest wash, with about 4 dishwasher tablets in it may also help. Dishwasher tablets have detergent and anti-bacterial agents in them that kill the bacteria that is in biological washing powder.
Jan 03, 2009 | LG WM2496H Front Load
Zanussi FJS1225W Front Load Washer Logo
20 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
