Question about Zanussi ZCG7902X Gas Kitchen Range
I have a zanussi gas cooker. we had a power cut and since then the clock and timer has been set on auto and just flashes all the time which means i cannot use the main oven. any advice on the problem
    Problem Solver:
  • 5 Answers
There should a symbol of a hand on one of the switches or buttons, press or turn and then it should set to manual.
Posted on Oct 11, 2009
My zanussi cooker isn't working after a power cut...even the timer/clock isn't flashing to reset wht can I do
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Apr 06, 2016 | Zanussi Ovens
How do you set the clock on the Electrolux cooker?
You didn't specified the model of the oven so it is possible to set in a different way. There are several kinds of timer (with tree, four, five and six buttons) depending on the model of the oven. Here is explained how to set clock on the most common oven timer with three buttons.
First of all, the oven only operates when the time has been set.
When the appliance has been connected to the electrical supply or when there has been a power cut, the function indicator Time flashes automatically.
1. To change the time that has already repeatedly, until the function indicator Time flashes.
2. Set the current time using the "+" or "-" button.
After approx. 5 seconds, the flashing stops and the clock displays the time of day set. The appliance is now ready to use.
Dado
Mar 18, 2015 | Electrolux Ovens
I have a green envoy gas cooker. mod no 050564096 serial no 001208. it has 5 buttons for the clock and timer and i dont know how to set it after we had a power cut. the rings work and small oven and...
I have a manual for the 850 DO and it says the following
Setting the "time of day"
1. Switch on electricity supply to the appliance
The display will flash
2. Press and release the time of day button
3. Set the time of day with the plus and minus buttons
4. The time will be set 7 seconds after the last plus or minus operation.
Hope this helps!
Nov 06, 2010 | Stoves 850DODLM Gas Kitchen Range
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Auto light wont fo off
good day,
hope this link below will solve your problem.
ovens
Aug 15, 2008 | Rangemaster 110 (Gas) Kitchen Range
Delonghi DFS901SS
have the same problem as you all. i myself removed the top of the hob to reveal a burnt out control switch . i have looked online for a replacemrnt , and it is £66 plus vat from delonghi but have found a cheaper one for £42, cant remember which site it was but type in cooker name and model on google and you will see it for yourself . good luck to you all, it seems like an easy fix
Mark
Oct 21, 2007 | Ovens
Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
May 04, 2007 | Zanussi ZCG7550 Gas Kitchen Range
Zanussi ZCG7902X Gas Kitchen Range Logo
474 people viewed this question
Top Zanussi Kitchen Ranges Experts
ray gallant
Paul Bade
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
