Question about Ricoh Office Equipment & Supplies
Ricoh Afico 2045S/P printing problem
I have a Ricoh Afico 2045S/P. When copying, printing or recieving faxes; the top two inches of the page is faded. (or the bottom depending on original placement) I replaced hot roller and drum 2500 copies ago. Any ideas?? Thanks in advance.
  • Ricoh Master
  • 3,267 Answers
The poblem should be Charge Roller cleaning blade AD04-1105. It will have to be replaced since a portion of it is unable or should I say 'overable'. Its resulting in first/initial section part(band) of the drum not developing the correct charge which in turn attracting the less toner -------- so faded output. The other possibility(quite remote) of the optical head of the laser not in synchronization with the rest of the components or there is a delaying the laser beam which is responsible for charging only that portion that is going to be printed. However first priority should be the disharging blade as mentioned above.................sodeep
Posted on Oct 02, 2009
All my colored prints have 2 one inch strips of faded color. What do I need to do?
First tray printing a black and white copy to see if you get same quality problem then try each individual color. If it shows on each copy then check The transfer belt Assy . If it only shows on one color then would be a drum unit or could be toner on laser shield glass . Other thing stop it during copying process and see where it's coming from look at drums and see if that shows up on them
Jul 10, 2015 | Ricoh Aficio CL3500N Laser Printer
Faded printing on top one inch of page
clean the print head glass
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 29, 2014 | Konica Minolta bizhub Office Equipment &...
I have a bizhub 300C. When I print a pdf the top inch is faded
Mike does this happen with all prints? does it go away if you change the orientation of the paper. portrait to landscape? Happen when you copy ? Try different file type does that change?
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Afico 1027 Printer not printing all the pages
I haven't seen such problem in this printer
Anyhow uninstall the printer software and reinstall it
You might have PCL6 driver
Try RPCS Driver from Ricoh Web
Nov 20, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Cannot find confirmation page "on off switch" Ricoh Afico 2035esp
User Tools/Fax/Parameter Settings. Personally I wouldn't mess with those, it's to easy to totally mess up the fax system if you flip the wrong bit switch setting. I threw my 450 programing guides away some time ago being that there's just a hand full of these things left in the hole country. I believe if you go to Ricoh's web site and go to the download page, you can download the fax user manual which if memory serves me (and it often doesn't), you'll find how to change the fax parameter settings.
Jul 29, 2009 | Ricoh Aficio 450 Copier
Blank print top 1 inch has print Toner cartidge has been changed
I need more information. If you make 20 copies do you still notice the problem or only when you receive a fax. What is your copy count (press life 1). Does it jam or make noises. At first glance I would say phone line problem. .
May 26, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Print too low from top of page
1-either the paper is not picking up in time
2-you need to change setting or scale
check the manual
http://www.retrevo.com/s/samsung+sf5100+manual
check "paper settings"
Jan 24, 2008 | Samsung SF-5100 Plain Paper Laser Fax
66 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
