Question about GE PFS22SBSSS Stainless Steel French Door Refrigerator
The ice maker is getting too cold at the bottom and the water is freezing. Repairman stated that they need the manual to adjust the temperature.
  • rolando ingking May 11, 2010
    The repairman could be right but they should have tried
    based on their experience.
  • 3,267 Answers
First of all water is not supposed to be present anywhere in the ice maker. only if the valve which fills up the ice trays & the water dispenser. Secondly its frost free too! This means that the water flowing into the ice maker is filling more water resulting in overflow & spillage of water on the bottom of the ice maker. The water valve which is responsible for controlling the quantity of water to the above, is at fault. The water valve is controlled by a solenoid which acts as an electromagnet & its rate of flow to the ice maker or should I say quantity, i.e. being controlled in turn by these coils. Should they weaken the valve will allow more water since the magnetic induction is a little weak. Water, if spilled over has to freeze because that part is a ICE maker. I hope you can catch my logic. If the fridge part/side was accumulating ice, then that's a different issue. If it is the second one kindly post it a comment so that I can also suggest the fault then.
Right now have the solenoid vale changed or adjusted if there is any electrician who can do so!
Mp puns intended............sodeep
Posted on Oct 02, 2009
Keeps running water and wont make ice
Ice Maker does not make ice; it takes water in and the cold freezer temperature causes the water to freez. Check your freezer temperature and overall performance of the refrigirator.
Oct 19, 2015 | Refrigerators
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
The tube that runs water into the ice maker on the inside of the ice maker keeps freezing over and I melt the ice only for it to happen again
i am sorry, i have an Amana and it did the same thing, the only thing i did was adjusted the freezer control, obviously, your freezer is getting below 0 degrees. Just raise up temperature some and you will be okay, if it continues then you may need to change out your cold control switch or freezer control.
Aug 23, 2009 | Refrigerators
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
The individual cubes turn into a huge block of ice
After the ice maker dump the ice it calls for water and pour water for no more than 7 seconds if is more and overflow the ice tray will leak on the ice bin and freezes all together , that means that the circuit board inside the ice maker is bad and need to be replaced but it will cost you almost as replace the ice maker and is easier ,two screws on the top of the ice maker and one in the bottom,a plug between the ice maker and the freezer wall ,and the plastic tube from what the water come into the ice maker.
Apr 07, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice maker not making ice
1)First check you have a water line that is getting water to the ice maker.
2)Ice makers have a valve at the bottom that open and close when told by the ice maker replace that cheap fix.
3)The ice maker needs to be repaced.
(how far into the line will the water freezehow far into the line will the water freeze)
.The valve at the back opens and closes will not leave water in the line to freeze.
Dec 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Open Questions:
See all GE PFS22SBSSS Stainless Steel French Door Questions
GE PFS22SBSSS Stainless Steel French Door Refrigerator Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
